Brand new Raspberry Pi 2 with the Skywriter Hat
Linux rpihobby01 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l GNU/Linux
curl -sSL get.pimoroni.com/skywriter | bash
sudo apt-get install python-smbus
sudo reboot
pi@rpihobby01:~ $ sudo i2cdetect -y 1
00: -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- 42 -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
So I pretty sure that means its all setup, but I did later run raspi-config again and enable SMB Bus and I2c was set enabled
sudo apt-get install python-dev python-xlib libxtst-dev libpng-dev python-pip pd
pi@rpihobby01:~/skywriter-hat-master/python/examples $ sudo ./test.py
Got firmware info
Got firmware info
Got firmware info
^CTraceback (most recent call last):
File "./test.py", line 37, in <module>
signal.pause()
KeyboardInterrupt
Got firmware info
The … relate to a number of the “Got firmware info” messages repeating
pi@rpihobby01:~/skywriter-hat-master/python/examples $ ./synth.py
Got firmware info
Populating temp PD file: /tmp/tmp1IjZUl
Got firmware info
Got firmware info
Got firmware info
Got firmware info
Started PD with PID: 2092
File: /tmp/tmp1IjZUl
Attempting to connect to PD
Connected to PD
Got firmware info
Got firmware info
Got firmware info
Got firmware info
File "./synth.py", line 16, in <module>
signal.pause()
KeyboardInterrupt
Killing PD instance
Got firmware info
Removing temp file
Got firmware info
Also the PD example failed
pi@rpihobby01:~/skywriter-hat-master/python/examples $ pd theremin.pd sh: 1: wish: not found
watchdog: signaling pd...
^CPd: signal 2
and nothing was displayed in an additional windows
tried a pip manual install
sudo pip install skywriter
Requirement already satisfied (use --upgrade to upgrade): skywriter in /usr/local/lib/python2.7/dist-packages
Cleaning up...
but it is not interested
tried a full manual install
git clone https://github.com/pimoroni/skywriter-hat
cd skywriter-hat/python/library
sudo python setup.py install
but resulted in the same “Get firmware info” messages
cloned the besherman pull request branch
pi@rpihobby01:~ $ mkdir tmp
pi@rpihobby01:~ $ cd tmp
pi@rpihobby01:~/tmp $ git clone https://github.com/besherman/skywriter-hat.git
Cloning into 'skywriter-hat'...
remote: Counting objects: 236, done.
remote: Total 236 (delta 0), reused 0 (delta 0), pack-reused 236
Receiving objects: 100% (236/236), 1.99 MiB | 1.00 MiB/s, done.
Resolving deltas: 100% (88/88), done.
Checking connectivity... done.
pi@rpihobby01:~/tmp $ cd skywriter-hat/python/library/
pi@rpihobby01:~/tmp/skywriter-hat/python/library $ sudo python setup.py install
running install
running bdist_egg
running egg_info
creating skywriter.egg-info
writing requirements to skywriter.egg-info/requires.txt
writing skywriter.egg-info/PKG-INFO
writing top-level names to skywriter.egg-info/top_level.txt
writing dependency_links to skywriter.egg-info/dependency_links.txt
writing manifest file 'skywriter.egg-info/SOURCES.txt'
reading manifest file 'skywriter.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_py
creating build
creating build/lib.linux-armv7l-2.7
copying skywriter.py -> build/lib.linux-armv7l-2.7
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
copying build/lib.linux-armv7l-2.7/skywriter.py -> build/bdist.linux-armv7l/egg
byte-compiling build/bdist.linux-armv7l/egg/skywriter.py to skywriter.pyc
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying skywriter.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying skywriter.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying skywriter.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying skywriter.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying skywriter.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist/skywriter-0.0.2-py2.7.egg' and adding 'build/bdist.linux-armv7l/egg' to it
removing 'build/bdist.linux-armv7l/egg' (and everything under it)
Processing skywriter-0.0.2-py2.7.egg
Removing /usr/local/lib/python2.7/dist-packages/skywriter-0.0.2-py2.7.egg
Copying skywriter-0.0.2-py2.7.egg to /usr/local/lib/python2.7/dist-packages
skywriter 0.0.2 is already the active version in easy-install.pth
Installed /usr/local/lib/python2.7/dist-packages/skywriter-0.0.2-py2.7.egg
Processing dependencies for skywriter==0.0.2
Searching for smbus==1.1
Best match: smbus 1.1
smbus 1.1 is already the active version in easy-install.pth
Using /usr/lib/python2.7/dist-packages
Finished processing dependencies for skywriter==0.0.2
pi@rpihobby01:~/tmp/skywriter-hat/python/library $ cd ../examples/
pi@rpihobby01:~/tmp/skywriter-hat/python/examples $ ./test.py
Got firmware info
Exception in thread Thread-1:
File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
self.run()
File "build/bdist.linux-armv7l/egg/skywriter.py", line 103, in run
if self.todo() == False:
File "build/bdist.linux-armv7l/egg/skywriter.py", line 332, in _do_poll
handle_firmware_info(data)
File "build/bdist.linux-armv7l/egg/skywriter.py", line 289, in handle_firmware_info
raise Exception("No valid GestIC Library could be located")
Exception: No valid GestIC Library could be located
signal.pause()
KeyboardInterrupt
what can I do next?
