I’ve been having trouble predicting how changes in the parameters to voice and play will affect the final sound produced. I built a small application with a simple UI that allows you to adjust various parameters and hear the result (it also shows the values as you would enter them into the method calls):
Thanks for sharing this. It’s a shame the Picosystem only has the Piezo buzzer not a proper little speaker, then again it wouldn’t be such a dinky little device if they started adding more. Another reason to consider getting a 32blit as well :)
I’ll have to see what I can try and make with the Picosystem for now though.
