Is it possible to connect the supply on the ADA5648 board to 12V so the output will switch between ground and 12V without damaging a Pico W which is providing the 3.3V input signal? The Mosfet is spec’d to 30V so it ought to handle 12V. My current drain will be very low as I’m using it to measure a 12V battery voltage using a potential divider with kOhm across the 12V battery and I need the Mosfet to switch the 12V on infrequently.
