Ultra-Slim Bluetooth Keyboard Pairing
ultra-slim Bluetooth keyboard.
I am trying to use this with a Pi 0.
I have asus Bluetooth working OK with a Bluetooth mouse.
I have tried to use the GUI Bluetooth to add the keyboard.
the search finds the device…
the pairing/setup option lets me enter passkey or use random passkey.
when I enter the key on the device I get pairing in progress then after about 10-20 secs failed message.
I tried using Pi terminal window.
Device is listed OK
the bluez simple-agent not found
I tried installing on widow 10 laptop and had similar problems.
Any ideas ?
Could it just be a faulty keyboard ?
Problem finally solved:
I switched on the device-tree option via raspi-config and now everything works
I am a beginner to Pi, but when I go from the main menu to preferences then to Rasp pi configuration I cannot find anything that looks related to device-tree.
Hi Rick,
On the prompt type sudo raspi-config
Them go to advanced, and there you’ll find device-tree option.
Regards,
Michel
hi Michel
Sorry to say but I have changed the device tree to yes , rebooted tried to install
the Bluetooth keyboard and I get the same problems
With the GUI Bluetooth manager
I get to pairing in progress, I ente the passkey and after about 20 secs
’failed to add device’ message
Using a terminal and following the tutorial
The install bluez says already on latest version
hcitool scan finds the device
the bluez-simple-agent hci0 command gets
bash: command not found
When you say every thing worked do you mean you installed
installed an ultra-slim Bluetooth keyboard and got it working ?
Best regards
Rick
I’ll be breaking out a Bluetooth Keyboard to try and test this myself this week- I’ve not set one up recently.
