My dream is for Pimoroni to expand on what they did with the Pico Unicorn (16x7) and upgrade it to a 16x16. They sort of achieved this with the Stellar Unicorn, however it is too large for my application, and has too many unnecessary features.
Until Pimoroni makes a 16x16 Pico Unicorn, I am searching for other options: Is it possible to wire a raspberry pi pico W to a unicorn hat HD? Would the new Stellar Unicorn driver work on that display? And if so, how would the pico be wired to the UHat HD pinout?
That would solve the hardware-part. On software-side, you would have to port the python-driver from Linux-python to Micropython (or whatever you use). I did this for a number of hats (see the repo for the code and examples). This could certainly also be done for this hat, since it only uses SPI.
I’m a bit of a novice, so I’m hoping for a dead-simple pinout diagram to show exactly how a Raspberry Pi Pico W would be wired to a Unicorn Hat HD. I think there are only 4 inputs needed. Unicorn HAT HD at Raspberry Pi GPIO Pinout
Just look for a Pico-W pinout diagram and wire mosi to mosi, miso to miso and so on. For chip-select you can take about any pin. Note the Pico W is very flexible regarding these SPI-pins (MOSI, MISO SCLK), so you can choose the pins that are most suitable (i.e. make wiring as easy as possible).
Watch out for the naming, in the typical Pico-W pinout diagram you now usually have TX, RX, and SCK:
