Hello,
I just got my Unicorn HAT today. I freshly installed the latest Raspbian version and used this command to install the drivers:
curl -sS get.pimoroni.com/unicornhat | bash
When I try the demos, nothing happens. There is no error and no LED is visible. I am using a 5V/2A power supply.
Any ideas? :/
Cheers
Do you have another Pi to try it on? I don’t have a Unicorn HAT with me to try and reproduce your problem.
Are you running any audio software, since that conflicts with the bizarre way the Unicorn HAT software works.
Thanks for your fast reply.
Yes, I have a RPiB+ here. I reinstalled Raspbian and installed the drivers with the same command like the RPi2 on it, but I got the same result. :( Nothing happens when I try the demos. The demos are working, I don’t get any errors. No LED is working.
Maybe the cute Unicorn (board) is broken? :(
I think it’s possible. There’s one way to find out for sure, drop us a support email with your order number/address and the shop crew should be able to sort you out with a replacement.
Sorry you got a dud :(
Okay, I got this form Amazon and I will send it back. I just created the ticket.
With a bit of luck I will receive my PiGlow today. Maybe I can play around with it. :D
Thanks for your help.
No problem!
Good luck with the PiGlow. I like that people have seen the PiGlow format as a challenge and done all sorts of interesting things with it.
