I am working on a project that requires a higher speed of refresh time for the 16x16 matrix. I was wondering if it is possible to get the schematic and the source code for the hat. If source code is not possible, schematic will be a tremendous help, otherwise, I have to sit down with a multimeter and find all the pins one by one. I really appreciate your help.
You’re not the first one to ask about this, so we might consider making an alternative firmware. Can you explain your project a little bit? How much higher refresh rate would you need? And would you be fine with a lower bit depth for the gamma correction as a result of a higher refresh rate?
