Hello!
I have a confession: I’m not a Python person. So, as soon as I received my Unicorn pHat I searched for a way to program it using NodeJS.
I found a really nice Node module wrapping the C library rpi_ws281x. It is called node-rpi-ws281x-native and it is available through npm or Github.
Here is a tiny example to get you up and running:
- First you need NodeJS. On the downloads page here select the ARM v6 tarball. I usually select the link in my browser and then use wget in an ssh terminal.
- Then you can install it by following this tutorial.
- Create a folder for your project somewhere. I created a
node-unicornfolder on my home directory:mkdir node-unicorn - In that directory create a new NodeJS project with the command
npm init. Pressenterfor all the questions and this will create apackage.jsonfor you. - Install the main module with the command:
npm install node-rpi-ws281x-native --save - Create a file called
index.jswith the following code inside:
var NUMBER_OF_LEDS = 32; // 32 leds in the Unicorn pHat
var strip = require('rpi-ws281x-native');
strip.init(NUMBER_OF_LEDS);
strip.setBrightness(50); // A value between 0 and 255
// The RGB colours of the LEDs. for instance 0xff0000 is red, 0x0000ff is blue, etc.
var leds = [
0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0
// Loop every 0.1 sec: randomise an index and a colour and display it
strip.render(leds);
var interval = setInterval(function() {
var randomIndex = Math.floor(Math.random() * NUMBER_OF_LEDS);
var randomColour = Math.floor(Math.random() * 0xffffff);
leds[randomIndex] = randomColour;
console.log('Rendering colour ' + randomColour + ' at index ' + randomIndex);
strip.render(leds);
}, 100);
// After 10 secondes, stop.
setTimeout(function () {
console.log('Stop!');
clearInterval(interval);
strip.reset();
}, 10000);
- Exactly as the Python library, you need to execute this code as root using:
sudo node index.js - For 10 seconds, every tenth of a second, the programm will pick a random LED and assign a random colour to it.
I know the library is lacking the nice set_pixel(x, y, r, g, b) and all the other high level functions. But it is not that hard to implement.
Now I’m trying to find how I could use this for a real life application :-D
