Weather hat enclosure options
hello,
I looked through the topics already discussing this but, wanted to ask a more updated option. I have the weather hat with a pi zero inside this Stevenson Screen But, I’m running into some issues. Where should I drill holes to be able to put the RJ11 cables since it doesn’t fit through the small hole in the bottom. What battery should I use for this to power the zero?
If this enclosure not the best option then which one would yall recommend? thank you.
I’d cut a small notch / slot, in the outside edge of the base. Just big enough for the cables. The RJ11’s are going to be plugged in when you close the Stevenson screen anyway. No need for a big hole.
you mean another hole around the other hole on the bottom side ?
Yes, just big enough for the two cables side by side.
cool. thank you. Was just trying to see a visual in my head since it helps understand more lol.
