Cases for Pi Zero with Automation Hat Mini?
are there any recommendations which case to use for a Raspberry Pi Zero with an Automation Hat Mini on top? It should offer some protection not only for the Pi, but also for the hat…
I’ve been using Pibow Cases in the past, but these do not cover any hats…
Thanks and best,
Febu
I’ve been switching to the extended long bolts and adding a diffuser.
Something like this may work in your case, no pun intended.
pHAT Diffuser - Pimoroni
With these,
Premium Pi standoff selection - Pimoroni
or these
Extended Pi Standoffs - Pimoroni
You need ones with the extra threaded stud at the end to go in where the screw normally goes on top of the pHat.
