WeatherHat Settings
I live in the US. Is there a way for the weatherhat sensors to display imperial readings?
With added conversion code yes. And a few cosmetic edits.
I live in Canada, and once apron a time I had to do it the other way.
For you it should be f=c*1.8+32
I tried. Maybe i didn’t do it right.
Post your code and I’ll be happy to have a look see.
Click the </> preformatted text option to wrap it in code tags.
That will retain indents / formatting etc.
Looks very complicated.
code from weather.py
#!/usr/bin/env python3
import math
import pathlib
import RPi.GPIO as GPIO
import ST7789
import yaml
from fonts.ttf import ManropeBold as UserFont
from PIL import Image, ImageDraw, ImageFont
import weatherhat
from weatherhat import history
FPS = 10
BUTTONS = [5, 6, 16, 24]
LABELS = [“A”, “B”, “X”, “Y”]
DISPLAY_WIDTH = 240
DISPLAY_HEIGHT = 240
SPI_SPEED_MHZ = 80
COLOR_WHITE = (255, 255, 255)
COLOR_BLUE = (31, 137, 251)
COLOR_GREEN = (99, 255, 124)
COLOR_YELLOW = (254, 219, 82)
COLOR_RED = (247, 0, 63)
COLOR_BLACK = (0, 0, 0)
COLOR_GREY = (100, 100, 100)
We can compensate for the heat of the Pi and other environmental conditions using a simple offset.
Change this number to adjust temperature compensation!
OFFSET = -14.5
class View:
def init(self, image):
self._image = image
self._draw = ImageDraw.Draw(image)
    self.font_large = ImageFont.truetype(UserFont, 80)
    self.font = ImageFont.truetype(UserFont, 50)
    self.font_medium = ImageFont.truetype(UserFont, 44)
    self.font_small = ImageFont.truetype(UserFont, 28)
@property
def canvas_width(self):
    return self._image.size[0]
@property
def canvas_height(self):
    return self._image.size[1]
def button_a(self):
    return False
def button_b(self):
    return False
def button_x(self):
    return False
def button_y(self):
    return False
def update(self):
    pass
def render(self):
    self.clear()
def clear(self):
    self._draw.rectangle((0, 0, self.canvas_width, self.canvas_height), (0, 0, 0))
class SensorView(View):
title = “”
GRAPH_BAR_WIDTH = 20
def __init__(self, image, sensordata, settings=None):
    View.__init__(self, image)
    self._data = sensordata
    self._settings = settings
def blend(self, a, b, factor):
    blend_b = factor
    blend_a = 1.0 - factor
    return tuple([int((a[i] * blend_a) + (b[i] * blend_b)) for i in range(3)])
def heading(self, data, units):
    if data < 100:
        data = "{:0.1f}".format(data)
    else:
        data = "{:0.0f}".format(data)
    tw, th = self._draw.textsize(data, self.font_large)
    self._draw.text(
        (0, 32),
        data,
        font=self.font_large,
        fill=COLOR_WHITE,
        anchor="lm"
    self._draw.text(
        (tw, 64),
        units,
        font=self.font_medium,
        fill=COLOR_WHITE,
        anchor="lb"
def footer(self, label):
    self._draw.text((int(self.canvas_width / 2), self.canvas_height - 30), label, font=self.font_medium, fill=COLOR_GREY, anchor="mm")
def graph(self, values, graph_x=0, graph_y=0, width=None, height=None, vmin=0, vmax=1.0, bar_width=2, colors=None):
    if not len(values):
        return
    if width is None:
        width = self.canvas_width
    if height is None:
        height = self.canvas_height
    if colors is None:
        #         Blue          Teal           Green        Yellow         Red
        colors = [(0, 0, 255), (0, 255, 255), (0, 255, 0), (255, 255, 0), (255, 0, 0)]
    vrange = vmax - vmin
    vstep = float(height) / vrange
    if vmin >= 0:
        midpoint_y = height
    else:
        midpoint_y = vmax * vstep
        self._draw.line((graph_x, graph_y + midpoint_y, graph_x + width, graph_y + midpoint_y), fill=COLOR_GREY)
    max_values = int(width / bar_width)
    values = [entry.value for entry in values[-max_values:]]
    for i, v in enumerate(values):
        v = min(vmax, max(vmin, v))
        offset_y = graph_y
        if vmin < 0:
            bar_height = midpoint_y * float(v) / float(vmax)
        else:
            bar_height = midpoint_y * float(v - vmin) / float(vmax - vmin)
        if v < 0:
            offset_y += midpoint_y
            bar_height = (height - midpoint_y) * float(abs(v)) / abs(vmin)
        color = float(v - vmin) / float(vmax - vmin) * (len(colors) - 1)
        color_idx = int(color)      # The integer part of color becomes our index into the colors array
        blend = color - color_idx   # The fractional part forms the blend amount between the two colours
        bar_color = colors[color_idx]
        if color_idx < len(colors) - 1:
            bar_color = self.blend(colors[color_idx], colors[color_idx + 1], blend)
            bar_color = bar_color
        x = (i * bar_width)
        if v < 0:
                graph_x + x, offset_y,
                graph_x + x + int(bar_width / 2), offset_y + bar_height
            ), fill=bar_color)
        else:
                graph_x + x, offset_y + midpoint_y - bar_height,
                graph_x + x + int(bar_width / 2), offset_y + midpoint_y
            ), fill=bar_color)
class MainView(SensorView):
“”"Main Overview.
Displays weather summary and navigation hints.
title = "Overview"
def draw_info(self, x, y, color, label, data, desc, right=False, vmin=0, vmax=20, graph_mode=False):
    w = 200
    o_x = 0 if right else 40
    if graph_mode:
        vmax = max(vmax, max([h.value for h in data]))  # auto ranging?
        self.graph(data, x + o_x + 30, y + 20, 180, 64, vmin=vmin, vmax=vmax, bar_width=20, colors=[color])
    else:
        if type(data) is list:
            if len(data) > 0:
                data = data[-1].value
            else:
                data = 0
        if data < 100:
        else:
        self._draw.text(
            (x + w + o_x, y + 20 + 32),  # Position is the right, center of the text
            data,
            fill=color,
            anchor="rm"  # Using "rm" stops text jumping vertically
    self._draw.text(
        (x + w + o_x, y + 90 + 40),
        desc,
        font=self.font,
        fill=COLOR_WHITE,
        anchor="rb"
    label_img = Image.new("RGB", (130, 40))
    label_draw = ImageDraw.Draw(label_img)
    label_draw.text((0, 40) if right else (0, 0), label, font=self.font_medium, fill=COLOR_GREY, anchor="lb" if right else "lt")
    label_img = label_img.rotate(90, expand=True)
    if right:
        self._image.paste(label_img, (x + w, y))
    else:
        self._image.paste(label_img, (x, y))
def render(self):
    SensorView.render(self)
    self.render_graphs()
def render_graphs(self, graph_mode=False):
    self.draw_info(0, 0, (20, 20, 220), "RAIN", self._data.rain_mm_sec.history(), "mm/s", vmax=self._settings.maximum_rain_mm, graph_mode=graph_mode)
    self.draw_info(0, 150, (20, 20, 220), "PRES", self._data.pressure.history(), "hPa", graph_mode=graph_mode)
    self.draw_info(0, 300, (20, 100, 220), "TEMP", self._data.temperature.history(), "°F", graph_mode=graph_mode, vmin=self._settings.minimum_temperature, vmax=self._settings.maximum_temperature)
    x = int(self.canvas_width / 2)
    self.draw_info(x, 0, (220, 20, 220), "WIND", self._data.wind_speed.history(), "m/s", right=True, graph_mode=graph_mode)
    self.draw_info(x, 150, (220, 100, 20), "LIGHT", self._data.lux.history(), "lux", right=True, graph_mode=graph_mode)
    self.draw_info(x, 300, (10, 10, 220), "HUM", self._data.relative_humidity.history(), "%rh", right=True, graph_mode=graph_mode)
class MainViewGraph(MainView):
title = “Overview: Graphs”
def render(self):
    self.render_graphs(graph_mode=True)
class WindDirectionView(SensorView):
“”“Wind Direction.”“”
title = "Wind"
metric = "m/sec"
    SensorView.__init__(self, image, sensordata, settings)
def render(self):
    ox = self.canvas_width / 2
    oy = 40 + ((self.canvas_height - 60) / 2)
    needle = self._data.needle
    speed_ms = self._data.wind_speed.average(60)
    # gust_ms = self._data.wind_speed.gust()
    compass_direction = self._data.wind_direction.average_compass()
    radius = 80
    speed_max = 4.4  # m/s
    speed = min(speed_ms, speed_max)
    speed /= float(speed_max)
    arrow_radius_min = 20
    arrow_radius_max = 60
    arrow_radius = (speed * (arrow_radius_max - arrow_radius_min)) + arrow_radius_min
    arrow_angle = math.radians(130)
    tx, ty = ox + math.sin(needle) * (radius - arrow_radius), oy - math.cos(needle) * (radius - arrow_radius)
    ax, ay = ox + math.sin(needle) * (radius - arrow_radius), oy - math.cos(needle) * (radius - arrow_radius)
    arrow_xy_a = ax + math.sin(needle - arrow_angle) * arrow_radius, ay - math.cos(needle - arrow_angle) * arrow_radius
    arrow_xy_b = ax + math.sin(needle) * arrow_radius, ay - math.cos(needle) * arrow_radius
    arrow_xy_c = ax + math.sin(needle + arrow_angle) * arrow_radius, ay - math.cos(needle + arrow_angle) * arrow_radius
    # Compass red end
    self._draw.line((
        ox,
        oy,
        tx,
        ty
    ), (255, 0, 0), 5)
    # Compass white end
    self._draw.line((
        ox,
        oy,
        ox + math.sin(needle - math.pi) * radius,
        oy - math.cos(needle - math.pi) * radius
    ), (255, 255, 255), 5)
    self._draw.polygon([arrow_xy_a, arrow_xy_b, arrow_xy_c], fill=(255, 0, 0))
    if self._settings.wind_trails:
        trails = 40
        trail_length = len(self._data.needle_trail)
        for i, p in enumerate(self._data.needle_trail):
            # r = radius
            r = radius + trails - (float(i) / trail_length * trails)
            x = ox + math.sin(p) * r
            y = oy - math.cos(p) * r
            self._draw.ellipse((x - 2, y - 2, x + 2, y + 2), (int(255 / trail_length * i), 0, 0))
    radius += 60
    for direction, name in weatherhat.wind_degrees_to_cardinal.items():
        p = math.radians(direction)
        x = ox + math.sin(p) * radius
        y = oy - math.cos(p) * radius
        name = "".join([word[0] for word in name.split(" ")])
        tw, th = self._draw.textsize(name, font=self.font_small)
        x -= tw / 2
        y -= th / 2
        self._draw.text((x, y), name, font=self.font_small, fill=COLOR_GREY)
    self.heading(speed_ms, self.metric)
    self.footer(self.title.upper())
    direction_text = "".join([word[0] for word in compass_direction.split(" ")])
    self._draw.text(
        (self.canvas_width, 32),
        direction_text,
        fill=COLOR_WHITE,
        anchor="rm"
class WindSpeedView(SensorView):
“”“Wind Speed.”“”
title = "WIND"
metric = "m/s"
def render(self):
    self.heading(
        self._data.wind_speed.latest().value,
        self.metric
    self.graph(
        graph_x=4,
        graph_y=70,
        width=self.canvas_width,
        height=self.canvas_height - 130,
        vmin=self._settings.minimum_wind_ms,
        vmax=self._settings.maximum_wind_ms,
        bar_width=self.GRAPH_BAR_WIDTH
class RainView(SensorView):
“”“Rain.”“”
title = "Rain"
metric = "mm/s"
def render(self):
    self.heading(
        self._data.rain_mm_sec.latest().value,
        self.metric
    self.graph(
        graph_x=4,
        graph_y=70,
        vmin=self._settings.minimum_rain_mm,
class TemperatureView(SensorView):
“”“Temperature.”“”
title = "TEMP"
metric = "C"
def render(self):
    self.heading(
        self._data.temperature.latest().value,
        self.metric
    self.graph(
        graph_x=4,
        graph_y=70,
        vmax=self._settings.maximum_temperature,
class LightView(SensorView):
“”“Light.”“”
title = "Light"
metric = "lux"
def render(self):
    self.heading(
        self._data.lux.latest().value,
        self.metric
    self.graph(
        self._data.lux.history(int(self.canvas_width / self.GRAPH_BAR_WIDTH)),
        graph_x=4,
        graph_y=70,
        vmin=self._settings.minimum_lux,
        vmax=self._settings.maximum_lux,
class PressureView(SensorView):
“”“Pressure.”“”
title = "PRESSURE"
metric = "hPa"
def render(self):
    self.heading(
        self._data.pressure.latest().value,
        self.metric
    self.graph(
        self._data.pressure.history(int(self.canvas_width / self.GRAPH_BAR_WIDTH)),
        graph_x=4,
        graph_y=70,
        vmin=self._settings.minimum_pressure,
        vmax=self._settings.maximum_pressure,
class HumidityView(SensorView):
“”“Pressure.”“”
title = "Humidity"
metric = "%rh"
def render(self):
    self.heading(
        self._data.relative_humidity.latest().value,
        self.metric
    self.graph(
        self._data.relative_humidity.history(int(self.canvas_width / self.GRAPH_BAR_WIDTH)),
        graph_x=4,
        graph_y=70,
        vmin=0,
        vmax=100,
class ViewController:
def init(self, views):
self.views = views
self._current_view = 0
self._current_subview = 0
    GPIO.setmode(GPIO.BCM)
    GPIO.setwarnings(False)
    GPIO.setup(BUTTONS, GPIO.IN, pull_up_down=GPIO.PUD_UP)
    for pin in BUTTONS:
        GPIO.add_event_detect(pin, GPIO.FALLING, self.handle_button, bouncetime=200)
def handle_button(self, pin):
    index = BUTTONS.index(pin)
    label = LABELS[index]
    if label == "A":  # Select View
        self.button_a()
    if label == "B":
        self.button_b()
    if label == "X":
        self.button_x()
    if label == "Y":
        self.button_y()
@property
def home(self):
    return self._current_view == 0 and self._current_subview == 0
def next_subview(self):
    view = self.views[self._current_view]
    if isinstance(view, tuple):
        self._current_subview += 1
        self._current_subview %= len(view)
def next_view(self):
    self._current_view += 1
    self._current_view %= len(self.views)
def prev_view(self):
    self._current_view -= 1
def get_current_view(self):
        view = view[self._current_subview]
    return view
@property
def view(self):
    return self.get_current_view()
def update(self):
    self.view.update()
def render(self):
    self.view.render()
def button_a(self):
    if not self.view.button_a():
        self.next_view()
def button_b(self):
    self.view.button_b()
def button_x(self):
    if not self.view.button_x():
        self.next_subview()
        return True
    return True
def button_y(self):
    return self.view.button_y()
class Config:
“”“Class to hold weather UI settings.”“”
def init(self, settings_file=“settings.yml”):
self._file = pathlib.Path(settings_file)
    self._last_save = None
    # Wind Settings
    self.wind_trails = True
    # BME280 Settings
    self.minimum_temperature = -10
    self.maximum_temperature = 40
    self.minimum_pressure = 1000
    self.maximum_pressure = 1100
    self.minimum_lux = 100
    self.maximum_lux = 1000
    self.minimum_rain_mm = 0
    self.maximum_rain_mm = 10
    self.minimum_wind_ms = 0
    self.maximum_wind_ms = 40
    self.load()
def load(self):
    if not self._file.is_file():
        return False
    try:
        self._config = yaml.safe_load(open(self._file))
    except yaml.parser.ParserError as e:
        raise yaml.parser.ParserError(
            "Error parsing settings file: {} ({})".format(self._file, e)
@property
def _config(self):
    options = {}
    for k, v in self.__dict__.items():
        if not k.startswith("_"):
            options[k] = v
    return options
@_config.setter
def _config(self, config):
        if k in config:
            setattr(self, k, config[k])
class SensorData:
AVERAGE_SAMPLES = 120
WIND_DIRECTION_AVERAGE_SAMPLES = 60
COMPASS_TRAIL_SIZE = 120
def __init__(self):
    self.sensor = weatherhat.WeatherHAT()
    self.temperature = history.History()
    self.pressure = history.History()
    self.humidity = history.History()
    self.relative_humidity = history.History()
    self.dewpoint = history.History()
    self.lux = history.History()
    self.wind_speed = history.WindSpeedHistory()
    self.wind_direction = history.WindDirectionHistory()
    self.rain_mm_sec = history.History()
    self.rain_total = 0
    # Track previous average values to give the compass a trail
    self.needle_trail = []
def update(self, interval=5.0):
    self.sensor.temperature_offset = OFFSET
    self.sensor.update(interval)
    self.temperature.append(self.sensor.temperature)
    self.pressure.append(self.sensor.pressure)
    self.humidity.append(self.sensor.humidity)
    self.relative_humidity.append(self.sensor.relative_humidity)
    self.dewpoint.append(self.sensor.dewpoint)
    self.lux.append(self.sensor.lux)
    if self.sensor.updated_wind_rain:
        self.rain_total = self.sensor.rain_total
    else:
        self.rain_total = 0
    self.wind_speed.append(self.sensor.wind_speed)
    self.wind_direction.append(self.sensor.wind_direction)
    self.rain_mm_sec.append(self.sensor.rain)
    self.needle = math.radians(self.wind_direction.average(self.WIND_DIRECTION_AVERAGE_SAMPLES))
    self.needle_trail.append(self.needle)
    self.needle_trail = self.needle_trail[-self.COMPASS_TRAIL_SIZE:]
def main():
display = ST7789.ST7789(
rotation=90,
port=0,
cs=1,
dc=9,
backlight=12,
spi_speed_hz=SPI_SPEED_MHZ * 1000 * 1000
image = Image.new(“RGBA”, (DISPLAY_WIDTH * 2, DISPLAY_HEIGHT * 2), color=(255, 255, 255))
sensordata = SensorData()
settings = Config()
viewcontroller = ViewController(
MainView(image, sensordata, settings),
MainViewGraph(image, sensordata, settings)
WindDirectionView(image, sensordata, settings),
WindSpeedView(image, sensordata, settings)
RainView(image, sensordata, settings),
LightView(image, sensordata, settings),
TemperatureView(image, sensordata, settings),
PressureView(image, sensordata, settings),
HumidityView(image, sensordata, settings)
    sensordata.update(interval=5.0)
    viewcontroller.update()
    viewcontroller.render()
    display.display(image.resize((DISPLAY_WIDTH, DISPLAY_HEIGHT)).convert("RGB"))
    time.sleep(1.0 / FPS)
if name == “main”:
main()
You need to use the Preformatted. Text option, </> for posting code.
Wow, that is a lot of code. I was not expecting it to be that complex. I will have a look see though.
weatherhat-python/examples/weather.py at main · pimoroni/weatherhat-python (github.com)
import math
import pathlib
import ST7789
import yaml
import weatherhat
FPS = 10
LABELS = ["A", "B", "X", "Y"]
DISPLAY_WIDTH = 240
SPI_SPEED_MHZ = 80
# We can compensate for the heat of the Pi and other environmental conditions using a simple offset.
# Change this number to adjust temperature compensation!
OFFSET = -7.5
class View:
    def __init__(self, image):
        self._image = image
    @property
    @property
    def button_a(self):
        return False
    def button_b(self):
        return False
    def button_x(self):
        return False
    def button_y(self):
        return False
    def update(self):
        pass
    def render(self):
        self.clear()
    def clear(self):
    title = ""
        blend_b = factor
        if data < 100:
        else:
        self._draw.text(
            (0, 32),
            data,
            fill=COLOR_WHITE,
            anchor="lm"
        self._draw.text(
            (tw, 64),
            units,
            fill=COLOR_WHITE,
            anchor="lb"
        if not len(values):
            return
        if width is None:
        if height is None:
        if colors is None:
        if vmin >= 0:
            midpoint_y = height
        else:
            offset_y = graph_y
            if vmin < 0:
            else:
            if v < 0:
            x = (i * bar_width)
            if v < 0:
                ), fill=bar_color)
            else:
                ), fill=bar_color)
    """Main Overview.
    title = "Overview"
        w = 200
        if graph_mode:
        else:
                if len(data) > 0:
                else:
                    data = 0
            if data < 100:
            else:
            self._draw.text(
                data,
                fill=color,
        self._draw.text(
            desc,
            font=self.font,
            fill=COLOR_WHITE,
            anchor="rb"
        if right:
        else:
    def render(self):
        self.draw_info(0, 300, (20, 100, 220), "TEMP", self._data.temperature.history(), "°C", graph_mode=graph_mode, vmin=self._settings.minimum_temperature, vmax=self._settings.maximum_temperature)
    title = "Overview: Graphs"
    def render(self):
    """Wind Direction."""
    title = "Wind"
    metric = "m/sec"
    def render(self):
        radius = 80
        # Compass red end
        self._draw.line((
            ox,
            oy,
            tx,
            ty
        ), (255, 0, 0), 5)
        # Compass white end
        self._draw.line((
            ox,
            oy,
            trails = 40
                # r = radius
        radius += 60
            x -= tw / 2
            y -= th / 2
        self._draw.text(
            direction_text,
            fill=COLOR_WHITE,
            anchor="rm"
    """Wind Speed."""
    title = "WIND"
    metric = "m/s"
    def render(self):
        self.heading(
            self.metric
        self.graph(
            graph_x=4,
            graph_y=70,
    """Rain."""
    title = "Rain"
    metric = "mm/s"
    def render(self):
        self.heading(
            self.metric
        self.graph(
            graph_x=4,
            graph_y=70,
    """Temperature."""
    title = "TEMP"
    metric = "°C"
    def render(self):
        self.heading(
            self.metric
        self.graph(
            graph_x=4,
            graph_y=70,
    """Light."""
    title = "Light"
    metric = "lux"
    def render(self):
        self.heading(
            self.metric
        self.graph(
            graph_x=4,
            graph_y=70,
    """Pressure."""
    title = "PRESSURE"
    metric = "hPa"
    def render(self):
        self.heading(
            self.metric
        self.graph(
            graph_x=4,
            graph_y=70,
    """Pressure."""
    title = "Humidity"
    metric = "%rh"
    def render(self):
        self.heading(
            self.metric
        self.graph(
            graph_x=4,
            graph_y=70,
            vmin=0,
            vmax=100,
    def __init__(self, views):
        self.views = views
        for pin in BUTTONS:
            self.button_a()
        if label == "B":
            self.button_b()
        if label == "X":
            self.button_x()
        if label == "Y":
            self.button_y()
    @property
    def home(self):
        return view
    @property
    def view(self):
    def update(self):
        self.view.update()
    def render(self):
        self.view.render()
    def button_a(self):
            self.next_view()
    def button_b(self):
    def button_x(self):
            self.next_subview()
            return True
        return True
    def button_y(self):
class Config:
    """Class to hold weather UI settings."""
    def __init__(self, settings_file="settings.yml"):
        # Wind Settings
        # BME280 Settings
        self.load()
    def load(self):
            return False
        try:
    @property
    def _config(self):
        options = {}
                options[k] = v
        return options
    @_config.setter
            if k in config:
class SensorData:
    def __init__(self):
        self.rain_total = 0
        else:
            self.rain_total = 0
def main():
        rotation=90,
        port=0,
        cs=1,
        dc=9,
        backlight=12,
    image = Image.new("RGBA", (DISPLAY_WIDTH * 2, DISPLAY_HEIGHT * 2), color=(255, 255, 255))
    settings = Config()
if __name__ == "__main__":
    main()
I’m lost in that wall of code.
@hel
Can it not be done by shoehorning the conversion formula into the OFFSET = -7.5 line?
Something like OFFSET = -7.5 * 1.8 + 32 which would convert to °F with the adjustment. Code may need refinement however. Or even at line 689. Sneaking the conversion into the def: statement there?
The actual polling of the bme280’s readings seems to be in the _init_.py could the conversion not be applied there at line 86?
I don’t have one of these boards or a spare Pi to test with. And my Python is poor at best. Just shooting the breeze.
Good luck!
-7.5 * .1 + 36.9 this works. Thanks Larry
That’s just adding a fixed value to degC measurements; you can’t convert to degF just by adding a constant.
Are you saying the weatherhat is
fixed on metrics.
The sensor reports in metric.
The weatherhat can display that data any way you want - in Fahrenheit or Kelvin or any other unit, but you would have to apply the appropriate conversion in weather.py to do so.
All I’m saying is, the conversion from C->F is not just a case of adding a fixed number, so just fiddling with OFFSET isn’t going to achieve what you want to achieve. Your solution is probably going to work when it’s about 50F, but get increasingly inaccurate at other temperatures.
I agree. But weather.py is a complicated program. I went through the docs and they did not provide a way to convert temperature. I would like to share my data. But right now only scientists will understand metric. Hopefully, someone from support will help. Thanks for your reply. Larry
I mean there’s quite a lot of code in there for sure, but as I said in your other thread you only really need to look at the part fetching the sensor data.
Specifically for temperature (I don’t know how you feel about the metric system for other measurements!) I would guess you want to add the conversion to line 672:
to
self.temperature.append(self.sensor.temperature * 1.8 + 32)
The documents probably don’t touch on this because, frankly, Fahrenheit isn’t widely used for weather temperatures outside of one or two small countries :-)
disclaimer: I don’t own, and have never even touched a WeatherHAT (although I would like one), and I don’t often fiddle with MicroPython, but that should be … about right?
Thanks. It worked. Are you saying the United States is a small country?
