When will the Pico GFX Pack be avalable?
What do you want to be able to do?
Make a handheld computer/gameboy/calculator
I gave up waiting and wrote my own. All you need is a display driver which can change the colour of a pixel. Then you can create a line. With a line you can draw rectangles, triangles etc and fill them in. You can create text characters and draw them in different sizes. I did it because the displays I was using (Waveshare), in addition to early Pimoroni Pico displays, only supplied the driver and a very limited set of GFX routines.
You can build interactive displays like this, without flicker.
The current Pico Graphics routines now supplies the means to do all this for their boards but if you are interested in a ābuild your ownā system there is information on my Instructables site.
Tonygo2ās Projects - Instructables
and more information here:
Can you access FrameBuffer in Pimoroni PicoGraphics Micropython W - Support - Pimoroni Buccaneers
I hope this helps - I find computer graphics so much fun!
I āthinkā they may be asking when will the actual
Pico GFX Pack - Pimoroni
be back in stock. If so Iād go this route.
You are right. Sorry I got the wrong end of the stick. I was thinking about the this library
GitHub - adafruit/micropython-adafruit-gfx: Pixel graphics drawing library for MicroPython.
which has since been deprecated -(not a word I use a lot!)
There is a Adafruit GFX library for Arduino - I used it many years ago.
I bought one of Adafruitās Matrix Portals. Wanted WIFI, at that time the Interstate 75 didnāt have WIFI. Learrning displayio etc has been a headache, to say the least.
LED RGB matrix is what Iām working with in displayio.
