Which connector?
The attached image shows the pcb from a Zigbee Fingerbot - can anyone identify which type of connectors the 2-pin and 3-pin are? Someone swiped the other part of the connector and left bare wires - I’m guessing they’re 1mm or 1.25mm pitch but looking at the JST site, none of the connectors they have are open on one side like these are.
Any ideas?
There is more than JST, there is Würth, TE-Connectivity, Amphenol…
Maybe you should try Digikey or Mouser. You can filter for wire-to-board connectors. Another option would be to use a picture with just the connector and try google picture search.
Yep, that’s what I’ve been doing - was just curious if anyone actually knew. Molex Picoblade seems to be the most similar so far.
Just in case it helps anyone in the future, these fit nicely:
adafruit 1.25mm pitch 2-pin
adafruit 1.25mm pitch 3-pin
