Part number of power connector
What is the format spec of the battery power connector on the " Enviro Weather (Pico W Aboard) - Board Only" ??
Thanks,
Gert
From the product page - “JST-PH connector” (a two-pin flavour)
Can you tell if this is correct part to order?
https://www.amazon.com/Upgraded-Connector-Battery-Inductrix-Eachine/dp/B07NWD5NTN
Thanks,
Gert
One of these maybe what your looking for?
JST-PH 2 Wire Assembly (pimoroni.com)
JST-PH 2-pin Jumper Cable - 100mm long (pimoroni.com)
As @alphanumeric says, Pimoroni carry leads that are definitely compatible.
The random Amazon cable appears to be the right form (it looks like the “2.0” is just helpfully adding the pin pitch to the description), however it is incredibly important that you check (and double check) the polarity of any cable you get elsewhere - do not just assume that red is positive and black is negative!
Hi All,
Thanks for the feedback. The Amazon lead will be in the mail and I’ll try it out. Checking polarity with ohm meter to known VDD / VSS pins on the board should be no problem.
Cheers,
Gert
