I’m new to Plasma Stick/Pico W and MicroPython.
I am playing with the examples onboard, and am having issues with the wireless connectivity.
I have populated WIFI_CONFIG.py appropriately. But it crashes out, and I keep seeing errors in Thonny:
PROBLEM IN THONNY'S BACK-END: Exception while handling 'Run' (ConnectionError: device reports readiness to read but returned no data (device disconnected or multiple access on port?)).
See Thonny's backend.log for more info.
You may need to press "Stop/Restart" or hard-reset your MicroPython device and try again.
Process ended with exit code 1.
Connection lost -- device reports readiness to read but returned no data (device disconnected or multiple access on port?)
Use Stop/Restart to reconnect.
Unable to connect to /dev/ttyACM0:
(I’ve looked in the backend.log, can’t really make much sense of it yet!)
Using some Pico W documentation I’ve managed to write my own script to connect to the network, so the basic functionality is there.
So what is wrong with the network_manager/uasyncio approach that is failing?
And what is the issue with Thonny?
Any tips, pointers, advice appreciated…
N.
