Yukon Serial Servo Module with Robotis Dynamixels
I have a Yukon and Serial Servo Module, and am wondering if anyone has got the Robotis Dynamixel TTL servos working with it.
I have tried with both AX and XL series servos and the LX 16A is supposedly Dynamixel compatible but with no joy. The closest I have got to communications it when I use the Servo Detect example, I get an error through the look saying the that a servo has reported its ID as None. I am guessing that’s the Dynamixel responding with an invalid packet because its address is held in another structure, but that is a guess.
Any thoughts would be appreciated. Thanks,
Carl
Hi @CarlC,
LX16A servos are electrically compatible with Dynamixels, and both use half-duplex UART, but the protocol is different between the two, which is why you are not getting a response from your servos.
It’s been on my personal list for a while to add Dynamixel support as I have a bunch of AX and XL servos at home I’d like to use one day, but sadly I have yet to have the chance and am unlikely to in the near future.
If you are up for adding support yourself (and raising a pull request please), then you’d need to make a file similar to: yukon/lib/pimoroni_yukon/devices/lx_servo.py at main · pimoroni/yukon · GitHub
(called dynamixel_servo.py for example) then implement a function for each of the Dynamixel protocol’s supported functions. Note there is a v1.0 protocol the AX servos use (DYNAMIXEL Protocol 1.0), and a v2.0 protocol the XL servos use (DYNAMIXEL Protocol 2.0), though I believe those can be switched to v1.0 with some magic command.
I imagine that’s not the answer you were looking for, but I hope it helps you anyway.
Thanks for your response. I haven’t written any Dynamixel interfaces for years (was a Bioloid kit beta tester and wrote a VB interface) but hey, a challenge is a challenge. Let me see if I can do something, just don’t hold your breath lol.
In case @CarlC is still interested I have written an initial version of the dynamixel_servo.py which I am current testing and tidying up.
One caveat is that I only have AX-12W servos so I have no way of developing or testing for any others. I am happy to work towards getting this available as a pull request if you are interested @ZodiusInfuser.
@mackemjohn Yes please! I have some AX-12A’s at home that I got with the intention of using in a project (and adding Yukon support for), but I never got a cool enough idea to push me. I’d be happy to test your API on my end with them. I think I have a few of their newer X servos too, somewhere…
Cool - I am already doing tidy up and testing, will then send a pull for you to take a look at and test with other servos.
On a related note, not that I think anyone will ever need it, but do you have any idea if hypothetically a string of different Servos, e.g. LX-16A and AX-12W could be used on the same single wire if they Baud Rate matched for each.
I haven’t looked at the low levels of the protocols in enough detail to be sure, but I think that the different Servo families might well just throw away invalid messages if the pre amble/checksum don’t match.
I suppose if the different servos rejected the signals for the other cleanly then they could share the same bus. I have never tested it though to verify either way.
Since the Yukon library makes use of a Duplexer class, I suppose there’d be nothing preventing that from being shared by two different servo protocols.
