I can’t make my servo 2040 board make a servo move, can anyone help?
I’m using circuit python for the code.
My setup is:
*Servo 2040 board connected to computer via USB C/ USB cable (my phone cable).
*I am using an external power supply (Variable power supply set at 5V, 30amps, which can higher or lower the voltage).
*One MG996r servo (to test).
I got AI to write some code (See below:)
import board
import pwmio
from adafruit_motor import servo
# Create a PWMOut object on GP1.
pwm = pwmio.PWMOut(board.GP1, duty_cycle=2 ** 15, frequency=50)
# Create a servo object from the PWMOut object.
my_servo = servo.Servo(pwm)
# Function to sweep the servo from 0 to 180 degrees and back.
def sweep_servo():
for angle in range(0, 180, 1): # 0-180 degrees, 1 degree step
my_servo.angle = angle
time.sleep(0.01)
for angle in range(180, 0, -1): # 180-0 degrees, 1 degree step
time.sleep(0.01)
sweep_servo()
time.sleep(1) # Pause for 1 second between sweeps,
(I saved it and ran it but it doesn’t work). I’m really frustrated!
Can anyone help?
Thanks in advance.
I am unfamiliar with CircuitPython’s servo support so am unsure if there are any obvious issues with that code, other than the pin number you’re using.
Which pin position on Servo 2040 have you plugged your servo into? Even though the pins are numbered 1 to 18 on the board, they are wired GP0 to GP17 on the chip. E.g. to control a servo connected to the pin position marked 1, you need to use GP0.
Is there any reason you are not using our MicroPython build for this board? You will not be able to use the full 18 servos (if that was your intention) with CircuitPython.
Hi Zodius,
Thanks for the reply, I’m happy to use micropython or anything else that works, it’s just the AI I used wrote it in circuit python. Is there a code for micropython or anything else that you use I can load up Thonny and micropython no a problem.
It’s really confusing, so are you saying that because I put the servo on pin one, it’s actually GP0? Thanks for that information, that helps a lot.
If you can show me micropython code that might work, I would be really grateful.
My goal is to build a humanoid robot upper body (2 servo’s for head, 6 servos for each arm meaning 2 shoulder, 2 elbow, 2 wrist.so 14 servo’s and maybe 2 for wheels).
If you can help me get even a couple of servos moving, it would get me off the ground.
Maybe this is a lesson in not taking what AI says at face value.
By the way, you never mentioned what error you got when trying to run that code. I just assumed it worked but nothing happened, but checking the CircuitPython build for Servo 2040, it looks like GP1 isn’t a defined pin anyway (instead SERVO_1 to SERVO_18 are), so it shouldn’t have worked, unless you were using a generic Pico build of CircuitPython, rather than the Servo 2040 specific one?
For this specific board that is true, but we have another board where Servo 1 starts at GP10, so you should generally avoid using GP numbers unless you have checked the schematic of the product first. Though, for both the Micropython and Circuitpython builds I’ve just linked to, these GP numbers are not defined, so you can happily use SERVO_1 for example, and it will be correct.
Thanks again, sorry I’m new to all this and where to find stuff. I entered the code from the link you sent(See below) but there was a traceback error
? I’ve pasted the error code below it. It seems not to recognise ‘servo’
import math
from servo import Servo, servo2040
Demonstrates how to create a Servo object and control it.
# Create a servo on pin 0
s = Servo(servo2040.SERVO_1)
# Enable the servo (this puts it at the middle)
s.enable()
time.sleep(2)
# Go to min
s.to_min()
time.sleep(2)
# Go to max
s.to_max()
time.sleep(2)
# Go back to mid
s.to_mid()
time.sleep(2)
SWEEPS = 3 # How many sweeps of the servo to perform
STEPS = 10 # The number of discrete sweep steps
STEPS_INTERVAL = 0.5 # The time in seconds between each step of the sequence
SWEEP_EXTENT = 90.0 # How far from zero to move the servo when sweeping
# Do a sine sweep
for j in range(SWEEPS):
for i in range(360):
s.value(math.sin(math.radians(i)) * SWEEP_EXTENT)
time.sleep(0.02)
# Do a stepped sweep
for i in range(0, STEPS):
s.to_percent(i, 0, STEPS, 0.0 - SWEEP_EXTENT, SWEEP_EXTENT)
time.sleep(STEPS_INTERVAL)
s.to_percent(i, STEPS, 0, 0.0 - SWEEP_EXTENT, SWEEP_EXTENT)
# Disable the servo
s.disable()
#Error Traceback (most recent call last):
File “”, line 3, in
ImportError: no module named ‘servo’
Just on setting it up, in the configure interpreter, I could only get the servo 2040 working when it was set to ‘Micropyhon - Raspberry Pi Pico - Board CDC - COM6’ is that ok?
This looks promising!! Ok, I flashed the 2040 with the uf2 that you sent in the link, I ran the code for one servo and it didn’t give an error code!
I saved it as code.py ran it but nothing happened, Should the RGB’s come on at all?
It definitely is connected as it shows up on computer. Variable power supply is on 5v 30amps connected to the external power, nothing happens with the servo, Not sure what im doing wrong.
One thing I noticed is that when I connect it to the computer I have to keep configure the interpreter and resetting it up and have to update it
Is it Micropython (Raspberry Pi Pico) or Micropython (RP2040) that I should configure it to?
Also once it is configured on Thonny ,it seems to disconnect and disappear from the laptop drive info, but I can see it on Thonny, including the code.py program. Is that normal?
You don’t need to save code onto the board to run it. You can run files that are local on your computer, via Thonny, using the run button up in the top left.
You can save code to the board, but it is not required for experimenting.
Now, if you want code to run at board power-up, with MicroPython you should call it main.py rather than code.py.
In that case it’s not loaded. Could you confirm which UF2 you have on the board? When you were doing the configure interpreter thing with Thonny, it’s possible it put on a default UF2 for the Pi Pico, rather than the one I linked to. It should say what version is running when the REPL first appears.
I removed the UF2 that was in there and dragged and dropped the pico v1.24.0 beta2 pimroni micropython into the 2040.
I typed help(“modules”) and saw all the files including servo in there like you showed.
I tried to run the code again and nothing happened it just highlighted the line 3 for a split second, but it didn’t give the error code this time.
I then typed the first 3 lines in the repl and no error this time, so I pasted the rest of the code in the repl, hit enter, then nothing.
I ran it again and in the REPL it said MPY: soft reboot and took ages for the >>> to come back.in the REPL.
Sorry its taking so long to reply, but there is a message limit and timer saying because i’m on my first day (?) I have to wait , so it may be a while before I reply back :(
Good news is that it doesn’t do the traceback error and I saw servo in the Help modules. So the UF2 you gave me must be copied now.
