Okay, thanks. So we can see there that you have your local loop. The 127.0.0.1 part.
Please try the following commands in a terminal.
Stop your WiFi service with: sudo ifdown wlan0
(may need to enter your password)
Restart it again with: sudo ifup wlan0
This should restart your Wi-Fi. Try using the ifconfig command again to confirm your network adapters.
The output should have the first part and then something that looks like this:
Ignore the “xx” parts, that’s just for security at my end. As mentioned previously, relocate your Zero2W close to your WiFi access point and restart it. Or use the commands above. It may automagically reappear. If not let the forum know the output of ifconfig again. Either me or another can help you solve this. :o)
Okay, thanks. We need to check though methodically. We can cross those off the list.
A few things to check that may be causing the issue:
Is there a valid wpa_supplicant.conf, with the correct details for your network?
Do you have another micro SD card that we could use with a fresh flash PiOS installed, to check if the WiFi component has failed?
Okay, thanks. Now we’ve gone through those steps. I’d concur that the Wi-Fi module may have failed. :o( Are you able to contact the vendor. Guessing it’s from Pimoroni, as you’re posting here.
If you were not aware the support/returns FAQ is here. Shoot them and email on sales@pimoroni.com. Probably your best next step.
They are very good. I’m not sure on the availability of the Zero2W currently. There may not be another one available if an exchange is deemed appropriate.
