Zero LiPo off/on voltage + BCM4
Hi there,
I have two questions;
  1. I read that the Zero Lipo has a low voltage cut off automatic shutdown at 3.0V to protect the battery, is there a similar automatic turn off voltage, kind of a hysteresis?
  2. I’m using BCM4 for a 1w temperature sensor, I note that the Zero Lipo uses this pin as a battery low indicator, will this conflict with my temperature sensor or will it matter? If there is a clash can you suggest a solution please?
Many thanks,
Paul
I’ll see if I can find out about #1.
As for #2. It’s possible to change the GPIO pin which 1-wire uses using dtoverlay=w1-gpio,gpiopin=N
Thanks for your reply…looking forward to hearing about #1 :)
Hi again,
just wondering if you have any news on this query?
Thanks,
Paul
Hi there, any update to my query at all at all?
Thanks,
Paul :)
Hi!
Did you mean “automatic turn on” in question #1? Yep, there is a small hysteresis, the Zero Lipo / Lipo Shim turns on at 3.25V and off at 3.0V.
