Zero lipo pin
Hi all,
Since I want to power my Pi with zero lipo module, I am wondering about whether the pinout of zero lipo will use up the GPIO pins of my Pi? I need to connect my Pi with other modules later.
Thank you very much!
Pinout is here, looks like all it uses is GPIO 4 for the Low Bat signal.
yes, I think so. So I can still use other pins of the Pi after I solder it on the pi?
Yes, as long as you have physical access to the pins.
