A+ Pibow Coupé without cutouts on the top
I’m planning a project that would require the A+ to have a smooth top surface, without the cutouts for the ports, cables, and GPIO that the A+ Coupé has. Is there now, or will there be a case like this?
Would it work to simply get two Coupés and use an extra layer and an upside down base to get the effect I need?
Thanks!
That sounds like it would work. However the base layer wouldn’t need to be upside-down.
I’d reckon you would need at least two additional layers to clear the header, and probably some extended screws to account for that.
Double up on layer 3, then use the top layer, and then finally but the extra bottom layer on the very top.
I’ll go grab some layers and give it a try to verify.
