I’m currently trying to work out a few things around what I need hardware wise, and how I go about putting things together, before trying to work out how I fit everything into the shell that I’ll have to put together.
I’m looking at using the following things at the moment:
1 x Pico H (SC0917, might move to a Pico WH later)
1 x Pico Enviro+ Pack (PIM65)
1 x LiPo Amigo Pro (PIM612)
1x LiPo Battery Pack – 1200mAh (BAT0004)
I suspect that I’ll need a cable to deliver the power, I suspect that the JST-PH 2 Wire Assembly (CAB1001) might be what I’m looking for, but if there is an easier connection, please let me know!
I’d then like to be able to drive at least 1 servo, and 12 addressable LEDs.
For the LEDs, I think that I’ll need:
1 x Flexible RGBW LED Strip (COM3204)
3 x LED Strip Connector Cable (CAB2000) - I may get away with 1 and splitting it in half, but I’d rather have too many here than not enough.
I don’t know how this would be connected on with the Pack on the Pico though, if someone could explain for me that would be amazing
For the Servo I had been looking at:
1 x DS-929MG (COR-DS929-MG)
They are currently out of stock, and I’m not sure how fast they will be back. I’d love a suggestion for a replacement that I could maybe use. I’m also not sure how this should be connected.
All help thankfully received!
