Hi everyone,
I’m looking for help recovering my Pimoroni Badger 2350.
The device originally worked perfectly with its factory firmware. I had not updated or modified it before attempting to install MicroPython.
What happened:
I attempted to flash badger-v3.1.1-micropython-with-filesystem.uf2. Since then, the screen has remained completely blank.
Current symptoms:
- The red light stays on.
- The display remains blank after reboot.
- I can enter RP2350 BOOTSEL mode using BOOT + RESET.
- My Mac detects the device as RP2350 Boot.
- The RP2350 drive appears in Finder.
- The drive disappears after copying a UF2 file.
- Double-tapping RESET does not expose the Badger2350 filesystem drive.
- No /dev/cu.usbmodem… serial port appears on macOS.
- Thonny cannot connect to the device.
What I’ve tried:
- Reflashed badger-v3.1.1-micropython-with-filesystem.uf2 using Finder and Terminal.
- Flashed using picotool load -v -x.
- picotool reported 100% loading and successful flash verification.
- The device rebooted, but the display remained blank.
- Checked USB detection and available serial ports.
I’m using macOS and a USB-C to USB-C cable connected directly to the Mac.
Questions:
- Is there a recommended procedure to restore the original factory firmware?
- Could the flash or filesystem be corrupted even though picotool reports successful verification?
- Is there a known recovery procedure for a Badger 2350 that enters BOOTSEL mode but won’t boot the application?
- Is there a way to determine whether this is a firmware issue or hardware failure?
I’d appreciate any suggestions before attempting more recovery steps.
Thanks!
