BME688 (BME68X) not detected on RP2350 UL2 Enviro+
I ordered my Enviro+ and picow 2350 from Pimoroni a couple of weeks ago, and have installed the binary rpi_pico2_w-v1.26.1-micropython.uf2 from the rp2350 github repo.
I can connect via Thonny and write to the screen, but my attempts to read from the bme688 sensor get the RuntimeError “BreakoutBME68X: breakout not found when initialising”.
Example code:
from breakout_bme68x import BreakoutBME68X
i2c = PimoroniI2C(sda=4, scl=5)
time.sleep(1) # allow sensor to power up
bme = BreakoutBME68X(i2c)
I’ll note that this code:
print([hex(x) for x in i2c.scan()])
gives the output:
[‘0x23’, ‘0x77’]
So it is there… am I using the wrong file or need different paramters?
thanks,
Philip
What test file / code are you using? A link to it would help.
If you click the preformated text button </> if will retain the indents etc.
I would give this one a try,
or even this one that is for the Enviro+ Pack.
Thank you, and apologies for the formatting.
Changing the constructor to add the address parameter was all I needed, so
bme = BreakoutBME68X(i2c, address=0x77)
worked perfectly.
Much appreciated!
