Trying to convert weather.py to work with Open Meteo as Dark Sky API no longer exists.
Got so far, by getting “ValueError: Location should be a string” error.
What have I missed, broken etc?
Thank you.
N.B., Much of the commented-out code is the old Dark Sky code.
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import os
import datetime
import glob
import logging
import sys
# try:
import requests
import geocoder
# import lxml
# from bs4 import BeautifulSoup
# from PIL import Image
# from PIL import ImageFont
# from PIL import ImageDraw
# except ImportError:
# print("""
# This script requires several modules to run correctly.
# Install with:
# sudo pip install requests geocoder beautifulsoup4
# sudo apt install python{v}-lxml python{v}-pil
# """.format(v="" if sys.version_info.major == 2 else sys.version_info.major))
# sys.exit(1)
# import bme680
# from luma.core.interface.serial import spi
# from luma.core.error import DeviceNotFoundError
# from luma.oled.device import sh1106
TEMPERATURE_UPDATE_INTERVAL = 0.1 # in seconds
# Default to Sheffield-on-Sea for location
CITY = "Sheffield"
COUNTRYCODE = "GB"
# Used to calibrate the sensor
TEMP_OFFSET = 0.0
logging.basicConfig(level=os.environ.get("LOGLEVEL", "WARNING"))
print("""This Pimoroni Breakout Garden example requires a
BME680 Environmental Sensor Breakout and a 1.12" OLED Breakout.
This example turns your Breakout Garden into a mini weather display
combining indoor temperature and pressure data with a weather icon
indicating the current local weather conditions.
Press Ctrl+C a couple times to exit.
# Convert a city name and country code to latitude and longitude
def get_coords(address):
g = geocoder.arcgis(address)
coords = g.latlng
logging.info("Location coordinates: %s", coords)
return coords
###### Query Dark Sky (https://darksky.net/) to scrape current weather data
###### def get_weather(coords):
###### weather = {}
###### try:
###### res = requests.get("https://darksky.net/forecast/{}/uk212/en".format(","
###### .join([str(c) for c in coords])))
###### if res.status_code == 200:
###### soup = BeautifulSoup(res.content, "lxml")
###### curr = soup.find("span", "currently")
###### if curr:
###### img_name = curr.img["alt"].split()[0]
###### logging.info("Weather summary: %s", img_name)
###### weather["summary"] = img_name
###### except requests.exceptions.RequestException as e:
###### logging.error("Could not get weather data from DarkSky: {}".format(e))
###### pass
###### return weather
# Get the Inky Open Meteo weather data for the given location
location_string = "{city}, {countrycode}".format(city=CITY, countrycode=COUNTRYCODE)
weather = get_weather(location_string)
# Query OpenMeteo (https://open-meteo.com) to get current weather data
def get_weather(address):
coords = get_coords(address)
weather = {}
res = requests.get("https://api.open-meteo.com/v1/forecast?latitude=" + str(coords[0]) + "&longitude=" + str(coords[1]) + "¤t_weather=true")
j = json.loads(res.text)
current = j["current_weather"]
weather["temperature"] = current["temperature"]
weather["windspeed"] = current["windspeed"]
weather["weathercode"] = current["weathercode"]
return weather
else:
return weather
###### This maps the weather summary from Dark Sky
###### to the appropriate weather icons
###### icon_map = {
###### "snow": ["snow", "sleet"],
###### "rain": ["rain"],
###### "cloud": ["fog", "cloudy", "partly-cloudy-day", "partly-cloudy-night"],
###### "sun": ["clear-day", "clear-night"],
###### "storm": [],
###### "wind": ["wind"]
# Inky: This maps the weather code from Open Meteo
# Inky: to the appropriate weather icons
# Inky: Weather codes from https://open-meteo.com/en/docs
icon_map = {
"snow": [71, 73, 75, 77, 85, 86],
"rain": [51, 53, 55, 56, 57, 61, 63, 65, 66, 67, 80, 81, 82],
"cloud": [1, 2, 3, 45, 48],
"sun": [0],
"storm": [95, 96, 99],
"wind": []
# Pre-load icons into a dictionary with PIL
icons = {}
for icon in glob.glob("icons/*.png"):
icon_name = icon.split("/")[1].replace(".png", "")
icon_image = Image.open(icon)
icons[icon_name] = icon_image
coords = get_coords(location_string)
def get_weather_icon(weather):
if weather:
summary = weather["summary"]
for icon in icon_map:
if summary in icon_map[icon]:
logging.info("Weather icon: %s", icon)
return icons[icon]
logging.error("Could not determine icon for weather")
return None
else:
logging.error("No weather information provided to get icon")
return None
# Get initial weather data for the given location
weather_icon = get_weather_icon(get_weather(coords))
# Set up OLED
oled = sh1106(spi(port=0, device=1, gpio_DC=9), rotate=2, height=128, width=128)
# Set up BME680 sensor
sensor = bme680.BME680()
sensor.set_humidity_oversample(bme680.OS_2X)
sensor.set_pressure_oversample(bme680.OS_4X)
sensor.set_temperature_oversample(bme680.OS_8X)
sensor.set_filter(bme680.FILTER_SIZE_3)
sensor.set_temp_offset(TEMP_OFFSET)
# Load fonts
rr_path = os.path.abspath(os.path.join(os.path.dirname(__file__), 'fonts',
'Roboto-Regular.ttf'))
rb_path = os.path.abspath(os.path.join(os.path.dirname(__file__), 'fonts',
'Roboto-Black.ttf'))
rr_24 = ImageFont.truetype(rr_path, 24)
rb_20 = ImageFont.truetype(rb_path, 20)
rr_12 = ImageFont.truetype(rr_path, 12)
# Fetch sensor dating first so that device settings take effect
sensor.get_sensor_data()
# Initial values
low_temp = sensor.data.temperature
high_temp = sensor.data.temperature
curr_date = datetime.date.today().day
last_checked = time.time()
# Main loop
# Limit calls to Dark Sky to 1 per minute
if time.time() - last_checked > 60:
# Load in the background image
background = Image.open("images/weather.png").convert(oled.mode)
# Place the weather icon and draw the background
if weather_icon:
background.paste(weather_icon, (10, 46))
draw = ImageDraw.ImageDraw(background)
# Gets temp. and press. and keeps track of daily min and max temp
if sensor.get_sensor_data():
press = sensor.data.pressure
if datetime.datetime.today().day == curr_date:
if temp < low_temp:
low_temp = temp
elif temp > high_temp:
high_temp = temp
else:
curr_date = datetime.datetime.today().day
low_temp = temp
high_temp = temp
# Write temp. and press. to image
draw.text((8, 22), "{0:4.0f}".format(press),
fill="white", font=rb_20)
draw.text((86, 12), u"{0:2.0f}°".format(temp),
# Write min and max temp. to image
draw.text((80, 0), u"max: {0:2.0f}°".format(high_temp),
fill="white", font=rr_12)
draw.text((80, 110), u"min: {0:2.0f}°".format(low_temp),
# Write the 24h time and blink the separator every second
if int(time.time()) % 2 == 0:
draw.text((4, 98), datetime.datetime.now().strftime("%H:%M"),
fill="white", font=rr_24)
else:
draw.text((4, 98), datetime.datetime.now().strftime("%H %M"),
# These lines display the temp. on the thermometer image
draw.rectangle([(97, 43), (100, 86)], fill="black")
temp_offset = 86 - ((86 - 43) * ((temp - 20) / (32 - 20)))
draw.rectangle([(97, temp_offset), (100, 86)], fill="white")
# Display the completed image on the OLED
oled.display(background)
time.sleep(TEMPERATURE_UPDATE_INTERVAL)
