When running the LTR559 breakout example program ( pimoroni-pico/micropython/examples/breakout_ltr559/demo.py at main · pimoroni/pimoroni-pico · GitHub ) using pico_plus2-v1.29.0-2-pimoroni-micropython.uf2 on my Pico Plus 2 W (A4 stepping), without an LTR559 attached, it reports:
Found LTR559. Part ID: 0x01
Shouldn’t it raise an error, rather than claiming to have found a non-existent LTR559?
This problem also occurs with pico_plus2_rp2350-v0.0.9-pimoroni-micropython.uf2
Later I tried it on a Plasma 2040 W running picow-55ceb1fc3e50f14c1e1ea0be73c429e0ddb3a4e0-pimoroni-micropython.uf2 ( RV3028 BreakoutRTC - Pico 2W + Breakout Garden - device not recognised - #8 by hel ), and found that also claimed an LTR559 existed when it didn’t.
In all cases it works fine when the LTR559 breakout is plugged in.
I am trying to test whether an LTR559 is present or not. I have worked around this issue by leaving a short delay after initialisation, then calling get_reading() and checking for a None response, but surely this shouldn’t be necessary…
Has anyone else seen this behaviour?
