Can I return GPS antenna for replacement?
Can I return 2 GPS/GNSS antenna MCX EML ANT102 antennas in exchange for the Adafruit versions suitable for use with the Adafruit Ultimate GPS Breakout ADA746 please?
I purchased two GPS/GNSS antenna MCX EML ANT102 antennas from you along with other stuff including Adafruit Ultimate GPS Breakout ADA746. You were out of stock of the Adafruit antenna so I assumed that the alternative would work. Unfortunately the antenna has a different connector on it and so I can’t use them.
Regards
Steve
