Can the Pimoroni NVMe Base be installed upside-down (flipped orientation)?
Hi everyone,
I’m currently working on a Raspberry Pi 5 project using the Pimoroni NVMe Base and the official PCIe FFC cable (16-pin to 18-pin). For cooling reasons, I’m wondering if it’s safe and functional to mount the NVMe Base upside-down, so that the SSD and heatsink face upward, while the Raspberry Pi remains facing up as usual.
In this setup, the FFC cable would still go:
  • 16-pin end to the Pi 5 PCIe port,
  • 18-pin end to the NVMe Base,
    but the board orientation would be reversed vertically.
My questions:
  1. Is the FFC cable designed to work in this flipped orientation? (i.e., are the contacts and signal alignment symmetric?)
  2. Any electrical or mechanical risks I should be aware of when doing this?
I’d really appreciate any confirmation, photos, or experience from the community.
Thanks in advance!
I’m confused by your post?
Mine is configured as follows
Pi heatsink
Pi circuit board
NVME Drive
NVME Base circuit board
Which is as Pimoroni intended.
You can’t flip / rotate the ribbon cable at either end. You will get no connection at the connector.
This was my original side by side setup, that does have the NVME Base upside down. It also shows my current stacked setup.
My custom Pi 5 NVMe base Pibow case - Discussion / Projects - Pimoroni Buccaneers
Hey, thanks so much for your reply!
I actually came across your setup before — really appreciate you sharing it. I was also thinking of doing a similar side-by-side layout, but with the NVMe Base board facing up, so I could easily add a heatsink on top of the SSD.
I’m still in the planning stage and haven’t purchased the board yet, so I can’t check it myself.
Just wondering if that flipped configuration would still work.
Thanks again!
The NVME board can be mounted on top of the Pi 5, NVME drive on top open for cooling. You need longer standoffs, and likely the longer ribbon cable.
Why would you want to do that? You are not running a PC that utilizes all PCIe-lanes that the SSD could support. I really suggest that you keep things simple. It is a Pi5 after all.
Thanks a lot for your response, I really appreciate it!
You’re probably right, and honestly, I’m still very new to all of this. I just thought it would be fun (and a bit cooler-looking) to add a heatsink on top of the SSD. 😅
Also, I’ve heard that if you run things like a Bitcoin full node, NAS, and boot the OS from the same SSD, the drive can get pretty warm over time — especially since it’ll be running 24/7. In the future, I’d love to explore more advanced Bitcoin node stuff (like Lightning or other features I don’t even fully understand yet 😅), which might add a bit more load.
So yeah — it’s mostly about experimenting, learning, and maybe making the setup look a bit “serious” while I’m at it 😄
Thanks again for sharing your thoughts!
Yes, it can get warm, even hot. But normally the SSD will trigger a self-protection routine once you reach about 70°C. But I am not sure if Bitcoin mining does enough IO to put the SSD under stress. I thought this would be more of a GPU/CPU limited workload.
BTW: for your use-case, you should think about an Intel N100 mini PC instead. You will get a higher performing system for less money if you sum up all the extras you need for a Pi5. Those N100 based mini-PCs are incredibly cheap now a days and all of that in a only slightly larger package compared to a Pi5. And if you pay only a bit more, you will get even more power.
Thanks a lot for the insight — I really appreciate it. The Intel N100 mini PC sounds like a solid alternative I hadn’t considered before.
I’m currently working on a Pi5 setup for a Bitcoin node and home NAS, but your suggestion made me realize I should also explore other options that might offer better performance or value.
Definitely adding it to my research list — thanks again for the valuable input!
