Cannot get Adafruit Stereo Bonnet to work
I am trying to get the bonnet to work properly. I have it fully assembled and connected to a Raspberry pi 3. I’ve ran the setup found here https://learn.adafruit.com/adafruit-speaker-bonnet-for-raspberry-pi/raspberry-pi-usage At the end this is what it says:
[quote]Do you wish to test your system now? [y/N] y
Testing…
speaker-test 1.0.28
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Playback open error: -2,No such file or directory
All done!
Enjoy your new i2s amplifier![/quote]
I try to test them and the following is displayed:
[quote]speaker-test -c2
speaker-test 1.0.28
Using 16 octaves of pink noise
Playback open error: -2,No such file or directory[/quote]
The speaker never makes a sound, but when upon reboot it crackles when Raspbian is loading. What could the issue be? I’m running a fresh install of the latest version of Raspbian Jessie with Pixel. The only thing that is on Raspbian other than what it comes with is the Alexa sample program.
I’m having the exact same problem. It crackles upon booting but other than that I cant get any sound out of it. I´m running the latest distribution of the jessie full.
