Client hangs
I’m running a simple script that creates a new client, gets the temperature/pressure, prints them out, and exists (with a client.close() call).
This script is run every minute.
After a few hours, the script hangs (I’m unsure where, not done much debugging yet) and hence numbers stop being reported.
My actual question is: has anyone seen this behaviour before?
U
Can you post the code you are using? Also, how are you making the periodic call, via a cron job?
The script can be found here https://gist.github.com/ulises/0d687bde76d1c6f60f07f620ecd1fe40
This script is run by collectd. Ignore the stuff in {{ }} as that’s some templating stuff that gets filled in when this script is deployed (yes, I am making things /as/ convoluted ^.^)
For now I’ve resorted to running my script with timeout (http://linux.die.net/man/1/timeout) until I figure out why it’s hanging.
