Clipper 4g Hat issues
Hardware - Zero 2 with Clipper running PiOS Lite.
What is the best way to add apn user and passwords for the clipper?
Adding them into pap_secrets doesnt seem to work.
What are the status lights on the board saying?
I always have a green flashing signal and amber status, I cannot find what these refer too.
What power supply is recommened for the clipper hat? while testing if I have issues sometimes it just wont turn on even with 65watt tablet chargers, power banks, keysight power supply.
Using minicom and sending “AT+CPING=“www.baidu.com”,1,4,64,1000,10000,255” I get 4 successful pings “+CPING: 3,4,4,0,310,350,332”
I get an IP address with ppp0 but if I send ifconfig wlan0 down and then try to use something like pitunnel I cannot remote into the system as if ppp0 is doing nothing.
during all this testing my leds have never once changed to anything other than solid amber status and flashing green NET. Even while swapping antennas.
I have been trying to get this Hat working for a while so hopefully some of this will help.
All this is based on my own testing and guess work I am not a network enginner.
I am assuming the reader knows how to use nano, cat, bash and sudo.
If something doesnt make sense or written badly please let me know ( all brains work differently)
Board -
Amber light just means powered up.
Green light - Solid means no SIM or cannot access APN
- Flashing means SIM is connected
If using with a full sized PI it tends to not have power issues but if using with a Zero 2W I often have to take the hat off and leave to completely discharge before turning on again.
Settings-
Start by making a PPP config file no need for apn user name and password here.
sudo cp /etc/ppp/peers/provider /etc/ppp/peers/clipper
edit the info
sudo nano /etc/ppp/peers/clipper
# coment out user
# user "myusername"
#change "YOURAPN" to your own such as internet for vodafone
#change pap to gprs
connect "/usr/sbin/chat -v -f /etc/chatscripts/gprs -T "YOURAPN""
# Serial device to which the modem is connected.
#Pi5
#/dev/ttyAMA0
#All other Pis
/dev/ttyS0
# Disable Hardware Flow Control
nocrtscts
# disable modem control lines
local
next we need to add apn details into pap and chaps ( as I don’t know which is correct)
sudo nano /etc/ppp/pap-secrets
add in below inbound connections ( I dont think location makes a difference) change user and pass to correct details for your network.
"user" * "pass" *
now edit chaps which has different formatting.
sudo nano /etc/ppp/chap-secrets
add this line with your correct details.
user * pass
At this point you could turn on ppp0 and it should connect but I didn’t have net access so I had to do a few changes which is all answered by AI so if someone has better methods please say.
Internet settings -
turn on PPP0 to get your destination IP address
sudo pon clipper
wait a few seconds for it to be connected and check the details
ifconfig
this will return all your current connections we are after ppp0 if this isnt showing try sending pon again and waiting 30-60 seconds.
mine looks like this
ppp0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 10.78.000.000  netmask 255.255.255.255  destination 10.64.000.000
Using the destination ip we can now edit the ip-up file
sudo nano /etc/ppp/ip-up
add this at the bottom of the file and add in your destination address
#!/bin/bash
# Add default route through the PPP connection
/sbin/ip route add default via "destination address" dev "ppp0"
Once you have done this we need to add ipforwarding
sudo nano /etc/sysctl.conf
look for the line below and remove the # and space
net.ipv4.ip_forward = 1
to apply the changes send the command
sudo sysctl -p
I had to edit my NetworkManager conf for dns issues.
sudo nano /etc/NetworkManager/NetworkManager.conf
add in the below
[main]
dns=auto
Also added in DNS details into resolv
sudo nano /etc/resolv.conf
add the below to the file
nameserver 8.8.8.8
nameserver 1.1.1.1
stop this file being changed on boot
sudo chattr +i /etc/resolv.conf
if you need it to be changed again you can use
sudo chattr -i /etc/resolv.conf
At this point restart the pi
once you are back in use a service like pi tunnel or piconnect and ssh login.
send sudo pon clipper and wait for it to show in the ifconfig.
check your ip address with
curl icanhazip.com
if it is diffrent to the external IP of your other devices on home network it means the Pi us using the simcard. Now turn off wifi and see if you can use curl or something like apt update.
send the below command to turn off wifi
sudo ifconfig wlan0 down
I am now trying to get this to connect on boot but using a systemctl service I get the error
Jan 12 14:35:49 clipper chat[492]: SIGTERM
Jan 12 14:35:49 clipper pppd[489]: Child process /usr/sbin/chat -v -f /etc/chatscripts/gprs -T wlapn.com (pid 491) term>
Jan 12 14:35:49 clipper pppd[489]: Connect script failed
I have just stuck to cronjob to get the service started.
sudo user mod -aG dip "user"
Then added to crontab -e
@reboot sleep 60 && /usr/bin/pon clipper
Hopefully this helps someone or someone can help me with the next steps.
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
