Is it possible to use HyperPixel 4.0 display with an IQaudIO?
I realise that I will probably have to wire one or both rather than just plug on to the header, but will there be a pin conflict?
Mick
Mick
The pinout site is useful for this:
Unfortunately, the compatibility tool only supports Pimoroni boards, but it is pretty easy to compare boards visually. The Hyperpixel board uses practically every pin, though, so compatibility seems unlikely. It breaks out I2C, apparently, but that isn’t helpful for the I2S pins that the other board needs.
