Hello,
i want to convert images with Imagemagick and put them on InkypHAT. I am using a cron job to run a command like this:
The image has a very bad quality after this, but InkypHAT can load it. With other settings (better quality) I wasn’t able to load it to InkypHAT.
Is there a way to convert it right?
Thank you! Christian
There’s no universal right answer- since Inky pHAT is both low-resolution and, at most, 3 colours you need fine-grained control over the colour quantization and dithering of each image to get something passable.
It’s something of an involved topic- http://www.imagemagick.org/Usage/quantize/
It helps if you pre-select your images for low colour count and large details.
