Bought the DOT HAT ( https://shop.pimoroni.com/products/display-o-tron-hat ) and installed everything nicely. When running the demo files it gives:
pi@raspberrypi:~/Pimoroni/displayotron/dothat/basic $ sudo python backlight.py
This example shows you a feature of the Dot HAT backlight.
You should see a rainbow sweep across the whole display!
Press CTRL+C to exit.
File “backlight.py”, line 9, in
import dothat.backlight as backlight
File “/usr/local/lib/python2.7/dist-packages/dothat/backlight.py”, line 1, in
import sn3218, colorsys, math
File “/usr/local/lib/python2.7/dist-packages/sn3218.py”, line 112, in
enable_leds(0b111111111111111111)
File “/usr/local/lib/python2.7/dist-packages/sn3218.py”, line 60, in enable_leds
[enable_mask & 0x3F, (enable_mask >> 6) & 0x3F, (enable_mask >> 12) & 0X3F])
IOError: [Errno 5] Input/output error
pi@raspberrypi:~/Pimoroni/displayotron/dothat/basic $ python backlight.py
And:
pi@raspberrypi:~/Pimoroni/displayotron/dothat/basic $ i2cdetect -y 1
70: – -- – -- – -- – --
I’m no expert but neither a true noob. Where do I went wrong here ?
