Hi. I have just setup my new DOT3000 and although most of the sample scripts work OK the joystick script fails with a “Failed to add edge detection” message. This a pain as I also cannot get the radio script working for the same reason. I have double checked and reinstalled all the necessary “stuff” but to no avail. Can anyone help out?
Thanks for your reply. I tried your suggestion but nothing changed. I put a fresh install of Raspbian on my SD card and after updating I then fired up a script to install and configure everything automatically. This comes from the Pimoroni.com website
It still failed but after adjusting line 184 from 10 to 20 in the radio.py plugin, this resulted in sweet music coming from the headphones. It was suggested to me that maybe VLC was slow in responding to Pythons requests so try increasing the connection attempts.
I think it’s just a dodgy version of the RPi.GPIO library, or something to that effect. I found a bug report filed with this same error for a specific version. Glad you got it up and running though!
