Dear Forum,
I have two Displayotron HATS. I had one working at one time. Currently, neither of them are responsive after installing three different ways on either Raspberry Pi Zero W or Raspberry Pi 2. Each have been attempts with either Stretch or Jessie.
I have tried to install through Pimoroni Dashboard and the one-liner starting with curl -sS. On all these attempts, the Raspberry Pi operates normally with several different programs functioning successfully. Under all these attempts, the device has no output and screen is blank. I must be missing something.
The following is a session output to explain the problem:
Please help, Thank You, Frank.
pi@raspberrypi:~ ls
adafruit-pitft.sh Downloads Pictures python_games
Desktop install-piface-real-time-clock.sh Pimoroni Templates
Documents Music Public Videos
pi@raspberrypi:~ cd Pimoroni
pi@raspberrypi:~/Pimoroni ls
displayotron
pi@raspberrypi:~/Pimoroni cd displayotron/examples/dothat/basic
pi@raspberrypi:~/Pimoroni/displayotron/examples/dothat/basic ls
backlight.py graph.py hello_world.py ipaddr.py room.py touch.py
pi@raspberrypi:~/Pimoroni/displayotron/examples/dothat/basic python touch.py
File “touch.py”, line 6, in
import dothat.lcd as lcd
File “/usr/local/lib/python2.7/dist-packages/dothat/lcd.py”, line 6, in
lcd = st7036.st7036(register_select_pin=25, reset_pin=12)
File “/usr/lib/python2.7/dist-packages/st7036.py”, line 42, in init
self.spi.open(0, spi_chip_select)
IOError: [Errno 2] No such file or directory
pi@raspberrypi:~/Pimoroni/displayotron/examples/dothat/basic python hello_world.py
File "hello_world.py", line 3, in <module>
File "/usr/local/lib/python2.7/dist-packages/dothat/lcd.py", line 6, in <module>
File "/usr/lib/python2.7/dist-packages/st7036.py", line 42, in __init__
pi@raspberrypi:~/Pimoroni/displayotron/examples/dothat/basic python backlight.py
File “backlight.py”, line 7, in
pi@raspberrypi:~/Pimoroni/displayotron/examples/dothat/basic $
