I ve just got my enviro+ and connected to raspberry pi 3 but i think i got problem with lcd. In every python script i run from examples, including lcd.py i get the lcd on but nothing appears. Its only black with backlight led on. Any suggestions?
If the examples don’t run then it sounds like a bad display. If you feel confident you could check the connection of the display to the back of the board. (The brown flex cable) Otherwise I’d contact Pim for a replacement.
I have checked it, disconnect-reconnect it also. I will contact Pim. Thank you very much.
