I’m a novice and trying to learn so be kind!
I have successfully setup an Enviro Urban board with the data remaining on the board, downloading manually using thonny. I really want a hand-off online solution to collecting the data so trying Adafruit. For now I’ll ignore the setting up feed with Adafruit as ‘I think’ I have this sorted as everything connects (i.e. WiFi, url to Adafruit, keys and so on). The problem appears to be the data?
One of similar entries in the log.txt:
2023-12-14 12:24:56 [debug / 119kB] - upload issue ‘request failed - Record invalid. Failed to save data to smokey12/feeds/enviro, data missing required value’ - You may have run out of feeds to upload data to
I cannot find a clue to answer ‘data missing required value’ or ‘You may have run out of feeds…’ - pretty sure the latter is not the case as I’ve not managed to upload any data to Adafruit as yet. So what’s the required value I’m missing? Here is a copy of one of the JSON files:
{“nickname”: “smokey-garden”, “uid”: “e6616408438c5e2c”, “timestamp”: “2023-12-14T11:11:58Z”, “readings”: {“temperature”: 22.58, “humidity”: 46.83, “pressure”: 1011.89, “noise”: 0.027, “pm1”: 0, “pm2_5”: 0, “pm10”: 30}, “model”: “urban”}
If anyone can shed a light on this it would be much appreciated.
