I have a Pi Zero W with both Display-O-Tron and Speaker-Phat.
I 've already set the pivumeter’s brightness to 0 in the asound.conf but it is still making the dothat’s LEDs glitch when a sound is playing…
Is there a way to get permanently rid of pivumeter ?
Thanks,
Charles
Try editing /etc/asound.conf and changing:
pcm.softvol_and_pivumeter {
type softvol
slave.pcm "pivumeter"
control {
name "PCM"
card 0
to:
type softvol
slave.pcm "hw:0,0"
control {
name "PCM"
card 0
If yours is different, then you can use/change the file here. Sound will work if you just simply remove asound.conf, but it’s also used for software volume.
