Header holes on PIM447 Trackball Breakout slightly staggered?
Going by user photos, the offsets are not enough to prevent soldering a 5-pin header in place, but curious why the holes are NOT in perfect alignment, but instead slightly “sawtoothed”? Pins 2 & 4 (SDA & INT) are noticeably farther from the edge than the other 3 pins.
It means they’re slightly press-fit. Not enough to avoid soldering altogether, but as a short temporary thing it can work, and it can also make soldering easier as the pins hold themselves in the header while you do it. There are a few different Pimoroni products with that kind of staggering.
What he said, makes soldering easier as it stays in place.
OK, thanks… never had an issue with that, but it makes sense.
Might end up plugging this trackball right onto the back of my Pi 400, since the pinout matches GPIO 1-3-5-7-9…
I have one on my Pi 400. I have a Pi 400 Flat Hat hacker Plugged in.
The Trackball is on a Proto Zero that plugs into the Hat.
I put an RV3028 beside the trackball, I had room so why not.
I dig my camera out and post a picture latter on.
This is what i ended up with mounting my trackball. Looks like I need to get the vacuum out and clean up some cat hair.
This pin alignment (or better misalignment) is the breakout-garden magic. I was actually searching on Pimoroni’s site for an exact spec, but did not find anything. I wanted to use it for some of my own PCBs. I ended up needing three tries until I managed to get the offsets right.
Ooh, any chance you could share? Pimoroni don’t usually release PCB designs so I imagine releasing the staggering design didn’t occur to them.
Here are three PCBs I made:
The first one is a small PCB that adds an I2C connector. The second one is a RTC+I2C connector. The third is a power-control PCB. You can plug the latter two underneath the pico.
