Help please, I can not image or download openplotter to the SSD, RASPI imager, does not see the NVMe SSD to image OpenPlotter from SD card?
New Build - RPI5, MacAutherHat - IMU - power card, Maiana, PIM 700 NVMe 500GB base, HDMI card.
Help please, I can not image or download openplotter to the SSD, RPI imager, does not see the NVMe SSD to image OpenPlotter from SD card?
Same with SD card copier?
I have RPI running, just can not install OP to ssd, only have zip on sd, can not open or run?
Kind Regards
Have you tried using the “Use Custom” option?
Hello FGNS.
Thank you for your reply.
Yes, seems i am missing something, or the ssd is corrupted?
Interesting that the SSD is not showing, suggesting an issue with the NVMe base. Does an lsblk in the terminal also not show the SSD?
I think this is a one for support link here.
Hope that gets you up and running.
Submitted a suport ticket, thanks FGNS
