I just built a new picade console and everything is working great except I cannot get the Load/Save State hotkeys working.
Everything is stock Retropie 4.2 and picade pcb. I’ve mapped Left shoulder to button 3 and Right Shoulder to button 6 in Emulation Station. All other default hotkeys work except when I press “Select+Right Shoulder” or “Select+Left Shoulder” nothing happens. Any ideas? Thanks in advance.
I’ve noticed the same problem yesterday.
The “L” and “R” buttons (3&6) work in games as expected. But together with “Select” the don’t work as “Save” and “Load”.
I’m still running the default firmware on the Picade PCB.
I remember having the same trouble. My solution was to change the hotkey configuration so that increase/decrease save slot and save/load state where mapped to select and joystick up/down/left/right. I will check my config and post my solution later or on the weekend. Im on retropie 3.8 but it might work on 4.2.
So I got load state at joystick up, save state at joystick down, increase slot at joystick right and decrease slot at joystick left. Takes a little while to get used to but works like a charm.
