Hi, i working on a project where i need to send some data from an Arduino to a raspberry pi over i2c, with a hyperpixel display, as i2c is the only interface available when using the hyperpixel.
But i cant enable the i2c interface without the screen going completely blank, i have tried to enable i2c in the pi config menu on the pi and in the config.txt with the same results.
i have used the “new installation” (just the added lines in the config.txt) for the hyperpixel:
dtoverlay=vc4-kms-dpi-hyperpixel4
dtparam=rotate=90,touchscreen-swapped-x-y,touchscreen-inverted-y
I’m using the newest raspberry pi os:
Raspberry Pi OS with desktop
Release date: May 3rd 2023
System: 32-bit
Kernel version: 6.1
Debian version: 11 (bullseye)
