Hi.
I got Hyperpixel 4 to work in Volumio 2.673 on a Raspberry PI 2 Model B. The screen works perfectly (very nice!), but I cannot make the touch capability work (no /dev/input/touchscreen node).
In dmseg, I can see that the goodix driver is not being loaded at boot:
[   10.926918] i2c /dev entries driver
[   11.011425] systemd-udevd[176]: starting version 215
[   11.539022] gpio-10 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   11.539134] gpio-11 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   11.541982] i2c-gpio i2c@0: using lines 10 (SDA) and 11 (SCL)
[   11.674806] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[   11.677763] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
In /var/log/boot.log, the screen is correctly initiated:
[  OK  ] Started HyperPixel 4.0" LCD Display Initialization.
The i2cdetect shows:
volumio@volumio:~$ sudo i2cdetect -y 3
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- 5d -- --
70: -- -- -- -- -- -- -- --
Then, tt is in present in /sys/bus/i2c/devices/i2c-3
volumio@volumio:/sys/bus/i2c/devices/i2c-3$ ls -latr
total 0
drwxr-xr-x 4 root root    0 Dec 15 14:44 ..
-rw-r--r-- 1 root root 4096 Dec 15 14:44 uevent
lrwxrwxrwx 1 root root    0 Dec 15 14:44 subsystem -> ../../../../bus/i2c
-r--r--r-- 1 root root 4096 Dec 15 14:44 name
drwxr-xr-x 3 root root    0 Dec 15 14:44 i2c-dev
drwxr-xr-x 2 root root    0 Dec 15 14:51 power
lrwxrwxrwx 1 root root    0 Dec 15 14:51 of_node -> ../../../../firmware/devicetree/base/i2c@0
--w------- 1 root root 4096 Dec 15 14:51 new_device
lrwxrwxrwx 1 root root    0 Dec 15 14:51 device -> ../../i2c@0
--w------- 1 root root 4096 Dec 15 14:51 delete_device
volumio@volumio:/sys/bus/i2c/devices/i2c-3$ cat name
i2c@0
volumio@volumio:/sys/bus/i2c/devices/i2c-3$ cat uevent
OF_NAME=i2c
OF_FULLNAME=/i2c@0
OF_COMPATIBLE_0=i2c-gpio
OF_COMPATIBLE_N=1
But /proc/bus/input/devices is empty.
If I do a sudo modprobe goodix, it is loaded with no error, but still the digitiser do not work.
This is the goodix module info:
volumio@volumio:/sys/bus/i2c/devices/i2c-3$ sudo modinfo goodix
filename:       /lib/modules/4.19.79-v7+/kernel/drivers/input/touchscreen/goodix.ko
license:        GPL v2
description:    Goodix touchscreen driver
author:         Bastien Nocera <hadess@hadess.net>
author:         Benjamin Tissoires <benjamin.tissoires@gmail.com>
srcversion:     BA08C10B4BAF0E8784AAD02
alias:          i2c:GDIX1001:00
alias:          of:N*T*Cgoodix,gt967C*
alias:          of:N*T*Cgoodix,gt928C*
alias:          of:N*T*Cgoodix,gt9271C*
alias:          of:N*T*Cgoodix,gt927C*
alias:          of:N*T*Cgoodix,gt912C*
alias:          of:N*T*Cgoodix,gt9110C*
alias:          of:N*T*Cgoodix,gt911C*
alias:          of:N*T*Cgoodix,gt1151C*
depends:
intree:         Y
vermagic:       4.19.79-v7+ SMP mod_unload modversions ARMv7 p2v8
It’s almost, almost done.
What could be missing?
I would love to use this touchscreen.
Thanks!
