Hyperpixel 4 on RPi 400 -- rotate console?
Hi all
I’ve plugged the Hyperpixel 4 into a rPi 400, and the console is in portrait mode.
Is there an easy way to display the console in landscape mode?
I can boot X and use the hyperpixel-rotate command to rotate the X display – however, I’m not wanting to run X – I just want a simple console.
Cheers all
Steve
hello ,I dont have a hyperpixel ,but have a few different lcd’s ,I’m a bit of a novice ,but when i want to do what your wanting to do i follow this site ,
Thanks for the reply, but that doesn’t help here.
S
Sorted.
Found this link really helpful:
https://github.com/pimoroni/hyperpixel4/issues/39
These are the changes to config.txt that worked for me:
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
# dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
dtoverlay=hyperpixel4
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x7f216
dpi_timings=480 0 10 16 59 800 0 15 113 15 0 0 0 60 0 32000000 6
display_lcd_rotate=3
Disabling vc4-fkms-v3d will probably mean that the HDMI ports will no longer work – I’ve yet to check, but as I mentioned originally I’m just wanting the console on the Hyperpixel 4.
Rather nicely, ‘startx’ brings up X properly on the Hyperpixel 4, and touch is working just fine. (I did earlier run hyperpixel-rotate when I first started on this, so that may be a necessary step for this to work.)
