Hi, I’ve checked all the related topics in the forum but still in vain.
I just got my fresh hyperpixel 4 square non touch and my pi 4
I flash the sdcard, connect hyperpixel 4 square and run the command
curl -sSL https://get.pimoroni.com/hyperpixel4 | bash
And choose the square-pi4, after reboot nothing shows on the hyperpixel 4 square.
Here’s my system info:
pi@raspberrypi:~ $ cat /boot/config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=0
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=off
#dtparam=i2s=on
dtparam=spi=off
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
dtoverlay=hyperpixel4
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x7f226
dpi_timings=720 0 15 15 15 720 0 10 10 10 0 0 0 60 0 35113500 6
pi@raspberrypi:~ $ cat /boot/config.txt | grep i2c
dtparam=i2c_arm=off
pi@raspberrypi:~ $ cat /boot/config.txt | grep spi
dtparam=spi=off
dtparam=spi=off
> ^C
#hdmi_safe=1
disable_overscan=0
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=off
#dtparam=i2s=on
dtparam=spi=off
dtparam=audio=on
[pi4]
max_framebuffers=2
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
pi@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
pi@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 2019
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 64 MiB at 0x0000000037400000
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=720 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:55:1A:B7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=5e3da3da-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3932704K/4050944K available (8192K kernel code, 661K rwdata, 2352K rodata, 2048K init, 850K bss, 52704K reserved, 65536K cma-reserved, 3198976K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 662 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 851 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 28124 entries in 83 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000017] Switching to timer-based delay loop, resolution 18ns
[ 0.000241] Console: colour dummy device 80x30
[ 0.000265] console [tty1] enabled
[ 0.000305] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000327] pid_max: default: 32768 minimum: 301
[ 0.000589] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000607] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001359] CPU: Testing write buffer coherency: ok
[ 0.001765] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002407] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002564] rcu: Hierarchical SRCU implementation.
[ 0.003424] smp: Bringing up secondary CPUs ...
[ 0.004322] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005349] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006335] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006469] smp: Brought up 1 node, 4 CPUs
[ 0.006482] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006491] CPU: All CPU(s) started in HYP mode.
[ 0.006500] CPU: Virtualization extensions available.
[ 0.007272] devtmpfs: initialized
[ 0.017759] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.017967] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017987] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.020153] pinctrl core: initialized pinctrl subsystem
[ 0.020949] NET: Registered protocol family 16
[ 0.024126] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.025561] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.025571] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.025765] Serial: AMBA PL011 UART driver
[ 0.028925] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.063969] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.066019] vgaarb: loaded
[ 0.066387] SCSI subsystem initialized
[ 0.066587] usbcore: registered new interface driver usbfs
[ 0.066638] usbcore: registered new interface driver hub
[ 0.066733] usbcore: registered new device driver usb
[ 0.080354] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-09-24 17:34, variant start
[ 0.090094] raspberrypi-firmware soc:firmware: Firmware hash is cd3add54955f8fa065b414d8fc07c525e7ddffc8
[ 0.101715] clocksource: Switched to clocksource arch_sys_counter
[ 0.179134] VFS: Disk quotas dquot_6.6.0
[ 0.179211] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.179358] FS-Cache: Loaded
[ 0.179546] CacheFiles: Loaded
[ 0.188769] NET: Registered protocol family 2
[ 0.189413] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.189437] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.189508] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.189578] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.189704] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.189732] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.190027] NET: Registered protocol family 1
[ 0.190546] RPC: Registered named UNIX socket transport module.
[ 0.190556] RPC: Registered udp transport module.
[ 0.190565] RPC: Registered tcp transport module.
[ 0.190574] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.190589] PCI: CLS 0 bytes, default 64
[ 0.193642] Initialise system trusted keyrings
[ 0.193811] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.202688] FS-Cache: Netfs 'nfs' registered for caching
[ 0.203168] NFS: Registering the id_resolver key type
[ 0.203191] Key type id_resolver registered
[ 0.203201] Key type id_legacy registered
[ 0.203219] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.205450] Key type asymmetric registered
[ 0.205461] Asymmetric key parser 'x509' registered
[ 0.205568] bounce: pool size: 64 pages
[ 0.205607] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.205768] io scheduler noop registered
[ 0.205779] io scheduler deadline registered (default)
[ 0.205929] io scheduler cfq registered
[ 0.205939] io scheduler mq-deadline registered (default)
[ 0.205949] io scheduler kyber registered
[ 0.258976] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.258995] brcm-pcie fd500000.pcie: could not get clock
[ 0.259057] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.259094] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ 0.311778] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.312076] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.312091] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.312109] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.312157] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.312295] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.315055] PCI: bus0: Fast back to back transfers disabled
[ 0.315072] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.315275] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.315400] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.315721] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.318479] PCI: bus1: Fast back to back transfers disabled
[ 0.318495] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.318541] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.318560] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.318631] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.318648] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.318869] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.319042] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[ 0.319200] pcieport 0000:00:00.0: AER enabled with IRQ 53
[ 0.319369] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.319824] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.331890] Console: switching to colour frame buffer device 90x45
[ 0.334878] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 720x720
[ 0.337741] iproc-rng200 fe104000.rng: hwrng registered
[ 0.337945] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.338417] vc-sm: Videocore shared memory driver
[ 0.338795] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.348812] brd: module loaded
[ 0.358476] loop: module loaded
[ 0.359219] Loading iSCSI transport class v2.0-870.
[ 0.360895] libphy: Fixed MDIO Bus: probed
[ 0.361322] bcmgenet fd580000.genet: failed to get enet clock
[ 0.361338] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.361355] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.361371] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.361394] bcmgenet: Skipping UMAC reset
[ 0.361637] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.381744] libphy: bcmgenet MII bus: probed
[ 0.422258] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.423153] usbcore: registered new interface driver r8152
[ 0.423213] usbcore: registered new interface driver lan78xx
[ 0.423265] usbcore: registered new interface driver smsc95xx
[ 0.423570] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.423600] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.426090] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.426401] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[ 0.427256] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.427270] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.427281] usb usb1: Product: xHCI Host Controller
[ 0.427292] usb usb1: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[ 0.427302] usb usb1: SerialNumber: 0000:01:00.0
[ 0.427786] hub 1-0:1.0: USB hub found
[ 0.427867] hub 1-0:1.0: 1 port detected
[ 0.428333] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.428361] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.428380] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.428737] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.428750] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.428761] usb usb2: Product: xHCI Host Controller
[ 0.428772] usb usb2: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[ 0.428783] usb usb2: SerialNumber: 0000:01:00.0
[ 0.429269] hub 2-0:1.0: USB hub found
[ 0.429321] hub 2-0:1.0: 4 ports detected
[ 0.430473] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.456044] dwc_otg fe980000.usb: base=(ptrval)
[ 0.656349] Core Release: 2.80a
[ 0.656368] Setting default values for core params
[ 0.656399] Finished setting default values for core params
[ 0.856760] Using Buffer DMA mode
[ 0.856770] Periodic Transfer Interrupt Enhancement - disabled
[ 0.856780] Multiprocessor Interrupt Enhancement - disabled
[ 0.856790] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.856814] Dedicated Tx FIFOs mode
[ 0.857086] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = f3253000 dma = 0x00000000f7544000 len=9024
[ 0.857111] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.857123] dwc_otg: Microframe scheduler enabled
[ 0.857192] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.857208] WARN::hcd_init_fiq:458: FIQ ASM at c07b6224 length 36
[ 0.857225] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[ 0.857260] dwc_otg fe980000.usb: DWC OTG Controller
[ 0.857289] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ 0.857321] dwc_otg fe980000.usb: irq 37, io mem 0x00000000
[ 0.857374] Init: Port Power? op_state=1
[ 0.857383] Init: Power Port (0)
[ 0.857649] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.857663] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.857675] usb usb3: Product: DWC OTG Controller
[ 0.857686] usb usb3: Manufacturer: Linux 4.19.75-v7l+ dwc_otg_hcd
[ 0.857696] usb usb3: SerialNumber: fe980000.usb
[ 0.858212] hub 3-0:1.0: USB hub found
[ 0.858260] hub 3-0:1.0: 1 port detected
[ 0.858899] dwc_otg: FIQ enabled
[ 0.858908] dwc_otg: NAK holdoff enabled
[ 0.858917] dwc_otg: FIQ split-transaction FSM enabled
[ 0.858931] Module dwc_common_port init
[ 0.859152] usbcore: registered new interface driver uas
[ 0.859262] usbcore: registered new interface driver usb-storage
[ 0.859429] mousedev: PS/2 mouse device common for all mice
[ 0.860582] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.860807] bcm2835-cpufreq: min=600000 max=1500000
[ 0.861406] sdhci: Secure Digital Host Controller Interface driver
[ 0.861414] sdhci: Copyright(c) Pierre Ossman
[ 0.861846] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.862221] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.865490] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.865630] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.865789] usbcore: registered new interface driver usbhid
[ 0.865798] usbhid: USB HID core driver
[ 0.866743] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.868547] [vc_sm_connected_init]: start
[ 0.880065] [vc_sm_connected_init]: end - returning 0
[ 0.881143] Initializing XFRM netlink socket
[ 0.881170] NET: Registered protocol family 17
[ 0.881285] Key type dns_resolver registered
[ 0.881646] Registering SWP/SWPB emulation handler
[ 0.882300] registered taskstats version 1
[ 0.882317] Loading compiled-in X.509 certificates
[ 0.890010] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.890084] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.893054] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.893541] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.894157] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.894168] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.911752] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.920172] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ 0.939571] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.941194] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.942821] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.945723] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.947345] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.953040] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.955353] of_cfs_init
[ 0.955444] of_cfs_init: OK
[ 0.956067] Waiting for root device PARTUUID=5e3da3da-02...
[ 1.000130] random: fast init done
[ 1.053559] mmc0: new ultra high speed DDR50 SDXC card at address 0001
[ 1.054790] mmcblk0: mmc0:0001 EC2QT 59.6 GiB
[ 1.056411] mmcblk0: p1 p2
[ 1.059171] mmc1: new high speed SDIO card at address 0001
[ 1.083167] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.083215] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.088533] devtmpfs: mounted
[ 1.094959] Freeing unused kernel memory: 2048K
[ 1.096872] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 1.096887] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.096899] usb 1-1: Product: USB2.0 Hub
[ 1.098653] hub 1-1:1.0: USB hub found
[ 1.098919] hub 1-1:1.0: 4 ports detected
[ 1.111981] Run /sbin/init as init process
[ 1.421783] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[ 1.498022] systemd[1]: System time before build time, advancing clock.
[ 1.559838] usb 1-1.4: New USB device found, idVendor=047d, idProduct=8018, bcdDevice= 1.02
[ 1.559854] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.559867] usb 1-1.4: Product: Expert Wireless TB
[ 1.559880] usb 1-1.4: Manufacturer: Kensington
[ 1.580836] input: Kensington Expert Wireless TB Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:047D:8018.0001/input/input0
[ 1.581133] input: Kensington Expert Wireless TB Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:047D:8018.0001/input/input1
[ 1.595326] NET: Registered protocol family 10
[ 1.596555] Segment Routing with IPv6
[ 1.636591] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.637258] systemd[1]: Detected architecture arm.
[ 1.641956] hid-generic 0003:047D:8018.0001: input,hidraw0: USB HID v1.11 Mouse [Kensington Expert Wireless TB] on usb-0000:01:00.0-1.4/input0
[ 1.646784] systemd[1]: Set hostname to <raspberrypi>.
[ 1.647569] hid-generic 0003:047D:8018.0002: hiddev96,hidraw1: USB HID v1.10 Device [Kensington Expert Wireless TB] on usb-0000:01:00.0-1.4/input1
[ 1.649446] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 1.963064] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 1.963085] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.338419] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.347073] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.347546] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.348085] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.348613] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.349272] systemd[1]: Listening on udev Control Socket.
[ 2.349613] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.454357] i2c /dev entries driver
[ 3.003568] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.114573] systemd-journald[115]: Received request to flush runtime journal from PID 1
[ 3.593097] gpio-10 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 3.593172] gpio-11 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 3.594476] i2c-gpio i2c@0: using lines 10 (SDA) and 11 (SCL)
[ 3.631854] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 3.632424] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 3.634127] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 3.639161] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 3.675286] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.678011] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 3.678028] [vc_sm_connected_init]: start
[ 3.687558] media: Linux media interface: v0.10
[ 3.688148] [vc_sm_connected_init]: installed successfully
[ 3.708915] videodev: Linux video capture interface: v2.00
[ 3.750379] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.750705] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.777982] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.782703] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.837019] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 3.837060] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 3.852690] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 3.852724] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 3.863402] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 3.863433] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.073750] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.083276] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.185062] bcm2835_audio soc:audio: card created with 8 channels
[ 4.202429] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.251568] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.262450] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.263191] usbcore: registered new interface driver brcmfmac
[ 4.487147] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.501437] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 4.644328] edt_ft5x06 7-0048: touchscreen probe failed
[ 6.454142] random: crng init done
[ 6.454160] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.583836] uart-pl011 fe201000.serial: no DMA platform data
[ 6.718228] 8021q: 802.1Q VLAN Support v1.8
[ 7.008875] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 7.206704] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.206724] brcmfmac: power management disabled
[ 7.513014] bcmgenet: Skipping UMAC reset
[ 7.612212] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 7.612491] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.631899] bcmgenet fd580000.genet eth0: Link is Down
[ 9.666605] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 10.691426] fuse init (API version 7.27)
[ 13.289851] Bluetooth: Core ver 2.22
[ 13.289929] NET: Registered protocol family 31
[ 13.289939] Bluetooth: HCI device and connection manager initialized
[ 13.290223] Bluetooth: HCI socket layer initialized
[ 13.290239] Bluetooth: L2CAP socket layer initialized
[ 13.290290] Bluetooth: SCO socket layer initialized
[ 13.301634] Bluetooth: HCI UART driver ver 2.3
[ 13.301648] Bluetooth: HCI UART protocol H4 registered
[ 13.301842] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.302099] Bluetooth: HCI UART protocol Broadcom registered
[ 13.551356] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.551363] Bluetooth: BNEP filters: protocol multicast
[ 13.551375] Bluetooth: BNEP socket layer initialized
[ 13.615579] Bluetooth: RFCOMM TTY layer initialized
[ 13.615598] Bluetooth: RFCOMM socket layer initialized
[ 13.615613] Bluetooth: RFCOMM ver 1.11
Please help, thanks.
