HyperPixel 4" stucked on boot at "Registred framebuffer for display 0, size 480x320"
Hi, I’ve just bought the HyperPixel 4“ (looks beautiful and the backlight is very uniform( but I’m unable to load Pi-Hole or the desktop via UI, or anything.
After I installed the right driver the display is stucked at “Registred framebuffer for display 0, size 480x320”
Previously I have installed the driver “LCD35-Show”, I removed it with
sudo rm -rf LCD-show
and than Installed the Pimoroni driver, but the display has this error.
Rotated image
I also tried to rotate but it says
DISPLAY=:0.0 hyperpixel4-rotate left
Rotating display
/usr/bin/hyperpixel4-rotate: line 18: xrandr: command not found
File “”, line 3, in
ImportError: No module named screenlayout
Setting matrix: 0 -1 1 1 0 0
/usr/bin/hyperpixel4-rotate: line 10: xinput: command not found
Saving touch settings to /etc/udev/rules.d/98-hyperpixel4-calibration.rules
Thanks a lot!
hello, i dont have a fix for u ,i’m novice at best , what i do in cases like is start over ,I format and reinstall the Raspberry pi OS , did you check the learn section on install the pixel 4, good luck ,HyperPixel 4" stucked on boot at "Registred framebuffer for display 0, size 480x320"
Hello. I solved by myself, the commandto rotate the display, the non touch one is “display_rotate=3”
IMG_6585
