I’m new to the community and just started to build my first Raspberry 4 with HyperPixel4. The Problem I have belongs to the orientation of the screen. I want it to be landscape but it comes in portrait out of the box.
I freshly installed raspbian light and updated it. After that, I cloned: https://github.com/pimoroni/hyperpixel4/tree/pi4 and run the install script.
The display works fine but is in the wrong orientation. I googled the whole afternoon and tried different things to fix this problem on my own. All for nothing.
When I boot up without any changes to the config.txt. Raspbian boots fine on the little display and shows the console but in portrait orientation.
When I put display_rotate=1 into the config. The raspbian boots but the display stop in the boot process at [ OK ] Found device /dev/serial1. The display orientation is right now, but it’s frozen. What is kinda weird, the raspberry seems to finish booting normally in the background because I can connect via ssh after a while.
It would be nice to get some help. I try to attach some photos. Maybe that helps.
Kind regards
Hans
