Hyperpixel in Kali Linux
I tried to install my new hyperpixel panel on my raspberry 3 running kali linux today.
I used: curl https://get.pimoroni.com/hyperpixel | bash
got a error that i cannot have root access so i made a second account without superuser rights and tried again.
This time i got this error:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 38282 100 38282 0 0 7547 0 0:00:05 0:00:05 --:–:-- 8391
This script will install everything needed to use
HyperPixel
Always be careful when running scripts and commands copied
from the internet. Ensure they are from a trusted source.
If you want to see what this script does before running it,
you should run: ‘curl https://get.pimoroni.com/hyperpixel’
Your operating system is not supported, sorry!
As far as I know that installer is written for Raspbian. Thus the “your OS is not supported” message.
I just tried it in raspberian. There the install ran thru without errors. In the end it asked for a reboot typed y and i just got a black screen.
I had a monitor connected via hdmi to the pi at the same time so i disconnected it but it does not help. Also i tried to disconnect the screen and connect the hdmi again to the big monitor but i did not get a picture back.
I hit shift during boot to get into recovery and deleted the hyperpixel entrys from the config. Now i can see again but how do i get this to work?
Also is it normal that the backlight is constantly on before any drivers are installed?
I don’t personally own one, not yet anyway. I just know that Pimoroni’s installers are written for Raspbian. Just curious, did you use Jessie or Stretch? Did you have anything else connected to the GPIO?
Yes, the backlight has a pull-resistor on its control line so that it’s on by default.
Which version of Raspbian were you using? And which version of the Raspberry Pi?
My raspberry is a model 3 B.
First i had raspberian installed under noobs,
today i tried a clean install of raspberian from a image without noobs, i downloaded the image from the raspberian website (2017-11-29-raspbian-stretch.img) first i used sudo apt-get update, sudo apt-get upgrade and sudo apt-get dist-upgrade until nothing new came in. (Reboots in between) So i used the most recent version of raspberian.
Then i used the command: curl https://get.pimoroni.com/hyperpixel | bash
No errors came, i pressed y for reboot.
The display behaves the same as before with raspberian under noobs installed (no picture, backlicht on) the only difference is
without noobs installed i cannot even delete the hyperpixel entrys from my config to see anything again (with shift pressed in on boot nothing happens). But i can use my windows pc to edit the config on the sd card.
In case it matters here is the content of my config:
For more options and information see
http://rpf.io/configtxt
Some settings may impact device functionality. See link above for details
uncomment if you get no picture on HDMI for a default “safe” mode
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
#disable_overscan=1
uncomment the following to adjust overscan. Use positive numbers if console
goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
uncomment to force a console size. By default it will be display’s size minus
overscan.
#framebuffer_width=1280
#framebuffer_height=720
uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
uncomment to force a HDMI mode rather than DVI. This can make audio work in
DMT (computer monitor) modes
#hdmi_drive=2
uncomment to increase signal to HDMI, if you have interference, blanking, or
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
Additional overlays and parameters are documented /boot/overlays/README
Enable audio (loads snd_bcm2835)
dtparam=audio=on
HyperPixel LCD Settings
dtoverlay=hyperpixel
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
framebuffer_width=800
framebuffer_height=480
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x6f016
display_rotate=2
hdmi_timings=800 0 50 20 50 480 1 3 2 3 0 0 0 60 0 32000000 6
Use a basic GPIO backlight driver with on/off support
dtoverlay=hyperpixel-gpio-backlight
How many Amps is your power supply rated for?
I have tried my 2.5 Amp power supply which came in the set with the pi (Vilros Adapter), and a 3 amp power supply i had (Rydges SpeedPower)
Ok, just confirming it was a good capacity to rule it out as an issue. The hyperpixel likely draws a fair bit of current.
I found the error. It was one of the pins, i mesured them all with a meter and one had no connection for whatever reason, visually it looked sound. I replaced it and now it works! Thank you!
I still hope to get it to work in Kali linux, but i am glad it is not broken.
It works in Kali Linux!! So happy!_
Waaah!? How did you have it connected to your Pi?
Just those Pins that are used, do not know the name, seems one was not connected. I cannot really imagine it had no connection, its is metal on metal.
