Hello! I had a RPi 3 B+ with the Hyperpixel non-touch installed and running Kali on it and everything worked fine. It was mothballed for a bit and recently I decided to get it up and running again. I re-imaged the sd card with the latest Raspian-based kali image, but when I used the curl/bash command to fetch the Pimoroni configuration/installation script I now get “hardware not supported”. I see that the screen is getting power and I also saw that kali is supported in the script (and didn’t get the “OS not supported” message).
Full disclosure, got the “don’t run as root” message and created a sudo-capable user account prior to the “hardware not supported” message.
Any insight would be appreciated! Thanks in advance.
